Polymer80 Question...?
CJ7Pilot
18436572
BENEFACTOR
Gold Member
Marysville
CA
So I figured I ought to jump on this bandwagon before it's too late (here in California, anyway).
For those who may not know, in most of our great country it is legal to manufacture your own firearm for your own use, provided you are legally qualified to own a firearm.
To help out in this department, there are companies that manufacture 80% of a firearm receiver (in this case, an AR15 lower receiver), and sell you the resulting "paperweight," so you can complete the remaining 20%. Voila! You just manufactured your own firearm (in the legal sense, anyhow).
I just got two 80% blanks from Polymer80.com, one with a jig kit to finish it out, and the other without the jig.
My plan was to use the same jig on both receivers, but the directions say it's not recommended.
Looking at the jig, I think it would work just fine if I re-used it, as long as I was careful about positioning the drill bits.
So my question to any of you who may have done a Polymer80 build, is do you think I'm okay using the jig more than once, or should I just buy another one? :confused:
Thanks!
I don't have a clue as to the answer but I will be watching this with great interest! Sounds like a great way to build a rifle.
Let us know how it turns out! I've been wanting an honest opinion of how the polymer "feels" once it's done- stiffness and durability wise.
How many times do you think any manufacturer uses their jigs to build.
This project has been on the back burner for a while, but now I'm back to it.
I ruined the first lower I tried, mostly due to tired equipment, but I learned a few lessons as well.
After making taller, heavier jaws for my cross-slide vise, rebuilding my drill press spindle with new bearings and a heavy-duty chuck, and anchoring my drill press to the wall, I milled another lower last night... it turned out pretty well!
I've got one more to do... actually my wife will be doing it, as it's her build, but I'll be offering my thoughts as she goes...! ;)
Anyhow, here's how it looks milled out:
I'll get it put together this weekend, and maybe see how it shoots! :thumbsup:
I went ahead and assembled the rifle last night, just a basic .300BLK build.
It looks pretty good, everything fit, and everything functions... but not everything is perfect (or even good enough)!
These receivers are 80% pre-manufactured, and the 20% you do yourself includes drilling the holes for the hammer pin, the trigger pin, and the safety, and milling out the fire-control assembly pocket.
The plastic jig is "sacrificial," in that the guide holes for drilling are tapered to center the drill bit (you do this with a hand drill, not a drill press). You begin drilling in to the jig, and by the time the bit reaches the receiver, it's already centered. You just have to drill in about 1/4", then when you mill out the pocket, the pin and safety holes should come out clean and square.
My pin holes came out nicely, but my safety holes didn't line up perfectly. I had to "adjust" the holes with a drill bit to get the safety to fit all the way, and it's slightly out of square... but it works, and it's not sloppy.
I was more disappointed with holes that were drilled by the manufacturer, particularly the take-down pin detent-pin holes... they are either slightly undersized, or have debris in them, so the detent pins are binding, and I can't get them out. They do sort of work though, and I think they'll loosen up in time. I'll definitely run a drill bit down the holes on my wife's receiver!
The biggest disappointment of all was the rear take-down pin hole itself! When I finally attached my upper, the front take-down pin slid right in, the upper and lower receivers fit together acceptably well, but the rear take-down pin wouldn't go in. I looked in the hole with a flashlight, and the rear hole was about 1/16" to far to the rear! I had to elongate the holes toward the front so the take-down pin could slide in. It fits nice and tight now, but the holes have noticeable gaps behind the pin, and when I pull the pin out, it dangles loosely, just barely held in by the not-so-functional detent pin.
This will be a regular issue for me, because in California there's a new law coming up in January regarding detachable magazines. Basically, we will be required to "disassemble" the action to remove the magazine. One fix for this is to use a magazine release that can only be pushed with the upper receiver separated from the lower receiver... or partially so. The mag release I'm using requires me to pull the rear take-down pin, and tip up the upper receiver in order to drop the magazine (10 rounds only) and insert a new one.
So... I'm going to be fk'n around with that sloppy rear take-down pin a LOT!
I'm going to go out and shoot this thing over the weekend, and see how I like it, but I'm already thinking I'll probably buy a manufactured lower to replace the polymer, and I'll throw the polymer receiver in the back of my safe until I need it.
This has been fun, and I'm hoping I can correct most of these issues on my wife's build. I think these will make fine behind-the-seat rifles, but I would not recommend this route to anyone wanting to build a serious rifle.
I'll let you know how it shoots!
Well, I didn't get to shoot the AR today. It was cold, windy, and rainy, which was great for duck hunting, but not so good for sighting in a rifle.
However, I did partially disassemble the lower, and was able to get the detents out, and ream the holes. Everything is just right now, aside from the slightly mis-aligned safety (which really isn't an issue), and the sloppy rear take-down pin (which is functional, but really bugs me).
Interestingly, the take-down pin holes on my wife's un-finished lower are spot-on, as are the holes on the lower that I messed up, and on another one I bought as a gift for a friend... so I'm chalking my misfit up to a manufacturer defect.
Polymer80 is supposed to be pretty good about warranty issues, so I think I'll try to get a new lower from them, and send this one back.
I got to shoot it today (only ten rounds, but that's enough for first impressions)! :D
I set up a campaign sign as a target, and used the middle of an "e" as a bulls-eye. The first five shots were to get the scope roughly sighted in, about 3" high at 25 yards, which should equate to about a 100 yard zero. The second five rounds gave me about a 2" group from the kneeling position, no sling. That will tighten up considerably when I put a sling on it, and shoot from the sitting position (the ground was wet today). When I have more time, I'll do a real 50 yard zero, which should give me about 100 yard PBR.
To address Randyzzz's question, when I put the lower receiver on a mag-well block, clamp it in a vise, and wiggle the stock back and forth, the flex is very noticeable. However, when it's pinned to the upper, and you're handling it like a rifle, it feels as rigid as any other AR. There are videos online of guys abusing the heck out of rifles built with these receivers, dragging them around behind their ATVs, backing over them with pick-up trucks, etc... and they seem to hold up pretty well. My rifles will NEVER suffer such abuse, so I'm pretty comfortable with the polymer lower concept.
A word about the .300BLK... I've never shot one before today, and this thing is FUN! The recoil isn't bad at all, and it's not as obnoxiously loud as my .223 carbine, but when you pull the trigger, you know you're not just plinking with a .22!
Also, to my surprise, the brass all landed about 10 feet to my right, within about an 18" circle (very easy to find and retrieve)!
All-in-all, I think I'm going to like this rifle! :thumbsup:
So I contacted Polymer80 today, and they are perfectly willing to send me a new 80% lower under warranty... provided I send them a photo of my existing lower cut in half.
The alternative is to fill the take-down pin holes with epoxy, and re-drill them. I think I'll take my chances with a new lower.
This hurt, but the next one will be even better!
Okay, I guess it's time to bring this thread to a close.
All in all, I'm VERY satisfied with Polymer80s product, and customer service! Not only did they warranty the lower that had the mis-drilled take-down pin hole, but they warrantied the other damaged lower that was probably my fault.
I received the replacements earlier this week, and over this weekend my wife and I milled out our receivers, and built matching .300BLKs. Hers is olive drab with an illuminated tactical sight, and mine is flat dark earth (tan) with a more traditional rifle scope. Everything fits and functions perfectly!
I have one more to do, which will end up being a little different. I've got a side-charger upper to go with it, but I haven't decided on a a caliber. I'm thinking maybe a longer range rifle (6.5 Grendel) would be a fun build. A friend of mine really likes his .243WSSM... but I think that's really pushing the pressure limits of the AR15 platform....
Any suggestions? :shrug:
Someday when I fly across the states, I'll be sure to drop in! :thumbsup:
Looks like those came out nicely! I'm going to have to give one of those a try just for the fun of it. I'm looking at the James Madison Tactical models. Probably in 300BLK too. I also want to build a MP5 clone from a flat. The biggest problem with those is the parts kits go for $1500 :eek:
My wife says I'm never going to get any of my Jeeps done if I don't stop buying guns. Bought the Ruger American Predator 22 a while back, just brought home a Merlin 1895 45-70 Guide Gun... Plus a ton of ammo on the Black Friday sales.
My wife has uttered those very words, a time or two! Now that she's built her own AR though, she's got the bug... now she's looking at handguns, and wants to get her CCW!
You're going to enjoy that Guide Gun! I have a .444 set up with a scout scope, that generally fits the same niche. My favorite load cranks out a 270 grain soft point at 2200fps, which is getting in to the lighter end of .45-70 territory, and packs plenty of punch for my purposes. Pretty much any time I go to the range, I bring the .444 along, just because is so satisfying to shoot! :thumbsup:
It's a hoot to shoot, but even with the 325g loads it kicks hard. 2050 fps, 3032 ftlbs. After about 10 rds you're pretty much done. I cant wait to get the 500 grain Buffalo Bore ammo...
That Buffalo Bore load ought to be good for those elk over there in Medford that are fattening up in those pear orchards there
Sent from my iPad
Good grief....you're making me feel like a slacker. I only picked up a pair of S&W 29s last week. It was a deal I couldn't pass up and I don't even like shooting .44 mags.
