MC 2100 -slowly working on install- questions.
joshvt
Scrambler Enthusiast
charlotte
nc
I had a thread going as I slowly work on installing an MC 2100 I purchased from Gronk. Once started I decided to put on an aluminum valve cover and Felpro gasket in an effort to stop the oil leak. I have been cleaning things up as I go and taking my time to learn as I go. Thanks for the help you guys have given me so far.
For those of you that saw my question on the throttle plates- through some additional research i determined my linkage was bent and hitting the curb idle screw... I corrected that and throttle plates now open to a full 90 degrees (so much for gronk telling me it will be fine). I am about ready to put the carb on for good and get everything connected.
Unfortunately, as I was working on the vacuum lines yesterday, I noticed (or broke as I worked on it) that the nipple for the purge line on the charcoal canister is broken off. I am planning to leave the CTO and EGR in place and as best I can understand, the purge signal hose goes to the CTO. Has anyone had luck repairing a busted nipple, or am I in for a new charcoal canister? Are there reasons i should replace anyway- do they go bad, lose effectiveness, etc.?
I'd just replace it, doesn't sound like a repair location that's going to hold up.
Thanks for confirming my thoughts... Of course I can't find a replacement that is listed as a fit. I want a new one rather than gambling that a 30 year old purge valve will be good. I have found several that appear as though they would fit, but specific dimensions are not provided. Anyone got a model number for a charcoal canister replacement they have used recently?
You may want to PM spankrjs, he replaced one on a FI Scrambler, and was talking about replacing one on a Scrambler that he redid the entire emission system.
I am looking at replacing my carb with the one sold by gronk on ebay. What are your thoughts on the one you bought mc 2100, I have messaged his listing asking about it and had not gotten any replys. Dont know if i should go with him or not, the kit seems like it has eveything that just hooks right up to the 4.2l
I'll preface my comments by saying that I don't have mine up and running yet so my opinion may evolve. Here are some general thoughts:
After researching carbs, I decided the 2100 seemed like the best option. I knew going to the pick a part, finding the right carb and rebuilding it wasn't going to happen if I wanted this done any time soon. I read mixed reviews of Gronk and his carbs and decided to take a chance since I liked the idea of an all in one package that was ready to go. I didn't find another option
Since my Scrambler is not my DD, I have been taking this project slow and researching learning as I go. I can follow instructions, but I tend to like to understand why I am doing something. I have also decided to replace the valve cover, fuel lines and do some general clean up while I have everything apart. I also wanted to clean up the emissions stuff, but wanted to make sure I understood what I was eliminating. With kids, business, and other interests/ commitments I have been working on it when I can for about 2 weeks. I am finally ready to bolt up the carb and turn the key- hoping to find time before the weekend. Someone who was not doing this for the first time and more familiar with carbs and cj's could probably knock this out in a day.
Gronk's instructions are ok at explaining the "why" and are decent at telling you what to do, but definitely leave some gaps. To make things a little more complicated, there were many variations of the mc-2100- I notice subtle differences in many of the pictures I looked at while researching. If you are interested, here are some links that I found most educational and filled in some of the gaps:
Adventures Under The Hood: http://home.sprynet.com/~dale02/ I am sure this link has been posted on other threads. It does a very good job of explaining what everything emissions related does in stock form when the computer is present. It also gives some tips on simple tests to diagnose if certain emissions components are working.
MC2100 Set Up for a 258: http://street2mud.com/webfiles/MC-2100%20set%20up%20for%20a%20258.pdf This gives an extremely detailed explanation and diagrams of the carb itself and then instructions for adapting to a 258.
Motorcraft 2150 2V Carburetor: http://grantorinosport.org/bubbaf250/carb/carb02b.html The top of the page says this is a "Ford V8 Workshop" but this article is about the 2150 and not really specific to the engine. I found it to be another good source if you are interested in the inner-workings of the carb.
As for customer service... Let's just say that as a small business owner, Gronk's response time is not exactly what I would try to emulate. He has responded to my questions, but it usually takes 2-3 days minimum. His responses are typically concise so if you have questions make them very direct. The carb took about 2-3 weeks to get to me, but it did arrive within the date stated on his listing- not sure if he builds these to order or what.
As for the carb itself, it appears in good shape and has the Motorcraft stamp on it (I had read one review accusing him of selling knockoffs). I believe it is genuine. My biggest complaint is that the linkage arm was bent preventing it from reaching WOT. I posted about this a while back and struggled to find a definitive answer about the throttle plate position at WOT (They are supposed to be 90 degrees- mine were not). After confirming this, I bent the linkage and it now operates properly. When I contacted Gronk about this he said "The throttle plate should be good to go"... Not a huge deal but annoying and dents my confidence in him a bit... The other thing I wish I would have asked him was if it is possible to order a carb with a bowl vent. There are many variations of the mc 2100 and not all have the vent. Mine doesn't. Apparently the carb is vented internally when there is no bowl vent. I haven't really figured out how it vents without creating a gas smell, so am a little concerned I may get a gas smell in the garage. Maybe false concern- we will see. When I asked Gronk about this he said "You'll be good". At the end of the day, I don't have a ton of confidence in customer service and I am not sure what would happen if the carb has issues once I get it fired up. Hopefully that won't be the case.
Those are my random thoughts- I hope they help. Let me know if you have other questions.
Finally fired it up today. After some cranking she started right up. Idled a little rough at first. Once it was warmed up, I Used a vacuum gauge and timing light that displays rpm to adjust mixture screws and get it idling smoothly at 650rpm. I have never tuned a card before- this was way easier than I expected. Took it for a test drive- runs waaaaay better than ever before. Very excited. Next up is the nutter.
Great,, Cant wait for mine to arrive. I did install the distributor upgrade. i bought it off of ebay. That alone made a world of difference alone. The jeep actually idles and runs good. I probably really didnt even to buy the 2100, But I want everything running the best it can.
Congrats! I remember when I got the HEI and MC on, it was heaven compared to where it had been :thumbsup:
I knew you would be happy with it, it’s one of the best decisions I made on my 8. The nutter will be a piece of cake, I was a little hesitant with messing with the wiring but after reading a couple of articles and watching a video over on YouTube actually went well.
Regards,
Griff04
What exactely does the nutter do
It bypasses the AMC timing module (which never worked very well anyway), which operates using feedback from the Carter BBD carburetor.
Actually, now that Joshvt has replaced the Carter feedback carb with the MC2100, I'm not sure the timing module does anything at all. The Nutter bypass might not even be necessary. :shrug:
EDIT: I could be talking out my a**... that is all a distant memory for me. I did the Nutter bypass on my CJ7 years ago, then ripped everything out for a MOPAR MPI system. That's what really made my 258 come alive (that, and a 4.0HO head)!
I have read from several sources that doing the nutter is helpful even with the computer controlled carb out of the picture. Something about when the carb plug is disconnected the computer puts the ignition into limp mode. If true, limp mode doesn’t feel too bad! I’ll look forward to seeing what non-limp mode is like.
One word: HEI.
No more need for nutter or any of that ignition crap :thumbsup:
I already did the distributor cap switch with bigger wires and an E coil, made a big difference. There is a computorized box that is attached to the inside of the drivers side fender well on mine, Its has AMC and some numbers on it. It has melted somewhat and i have no idea what its for and cant find it in any of the chilton manuals. Any ideas what it does or if its even needed anymore
and i would have loved to have done the MOPAR MPI, but i cant find anywhere to get one. they quit making them
Yes it is needed for the TFI ignition, that's your ignition control module.
Here's an interesting link from someone that did both HEI and TFI:
http://keith.cj8.tripod.com/tfi_hei_comparison.htm
I replaced mine when I did the upgrade years ago, and the new one is leaking the potting out of it too.
Haven't noticed a problem, but it is only a matter of time when the electronics get exposed to the elements.
