Sticking Caliper...
John N
Addicted....Ex-SOA VP
Rockville
VA
I’m looking for some input. My left front caliper (Waggy 44 front) just started sticking. I drove it about 2 miles to a gas station today, it was fine on the way, coming home the caliper stuck. Brakes on that side got hot, I could smell it burning when I stopped, felt the heat at the hub and the Jeep pulled hard right when I was stopping.
I know it’s best to replace that caliper, even if I can break it free, but should I replace both? They’ve been on the Scrambler 10 years plus.
Thanks...
It's not a necessity to replace in pairs, but its highly reccomended. A caliper that is worn out has a lower clamping pressure than a brand new one and cause pulling and uneven wear on both pads and rotors. for what they cost you'll be money ahead doing both now.
The last time I changed my Dana 44 caliper it was about $20. Change both
It could also be the brake line, not the caliper. Old brake lines have a tendency to collapse inside, and restrict flow of the brake fluid back to the master cylinder. This can cause it to not release. This would also cause it to pull hard right when stopping, as brake fluid doesn't push as hard on the left caliper due to the obstruction. I have had this happen in a few different vehicles.
I always replace them in pairs. Then again, I thrive on overkill.
I bought the pair and new pads. I’m just waiting until I get my son’s Christmas gift out of the way in the shop to tear down the front end. I figured that I might as well install the set of alloy axles that I bought 2 or more years ago at the same time.
It took a little longer than I planned, but I finally got this done. At the same time, I installed the alloy axles that I had gotten a year or two ago and went through the wheel bearings. Next I’ll move on to changing the oil in the diffs and the transfer case.
:thumbsup: Good stuff!
Good deal. Now your ready for Whisky Run again :thumbsup:
