If it's there, it's in plastic under your driver's seat.Would like to know where I can locate a build sheet for my vehicle.
I had removed my hard top off my 1982 CJ8 Scrambler. Tried to put it back on but the screws won't go back in to hold it down. Looks like the screws were odd balls and probably not the original screws.
Did the windshield frame have nuts inside to connect the screws, or just screws to hold down the top?
I would like to put it back together the correct way. Any help would be greatly appreciated.
Thank you
As far as I know, there's no way to get a duplicate. You could maybe do a repro using information you have and an image of a true build sheet to work from, but you're asking to find information on a 35+y/o vehicle from a company that has changed hands 3-4 times since the original owner went out of business.I will check. Thank you.
Someone had mentioned it may be under the passenger seat, but it wasnt there.
It apparently had been removed by the previous or original owner and was never put back.
Is there any way I can get a duplicate made? If so who do I contact?
