- Ducor
- Ca
Part #4 Looks like a turn signal bezle. Or outer trim ring for the turn signal Lens.
Factory Exhaust Hanger Bracket and Bolt...The most rearward one behind the tire..... Getting hard to find in the Rust Belt...most I find here are rusted beyond use....nice find!
Awesomeness!Factory Exhaust Hanger Bracket and Bolt...The most rearward one behind the tire..... Getting hard to find in the Rust Belt...most I find here are rusted beyond use....nice find!
A portion of the factory steering stabilizer mount, that goes to the tie rod....the other side would have a small curved piece of metal and is attached with two U bolts.
FYI, Jak is 1000 percent right on his answer...those are the OEM frame side reinforcements when either the OEM rear CJ-8 step bumper or "draw bar" on CJ5 or CJ7 was equipped.
After doing that a few times you can probably get that time down to 7-8 hours.Been distracted again. Had to change the starter on my Wife’s land cruiser. Why Toyota decided to put a starter behind an exhaust manifold requiring you to drop the exhaust to replace a starter I don’t know! Took 10 hours to get the impossibly to reach bolts removed and the new starter installed. No I get to do it all again because the rebuilt starter from o’reilleys is intermittent and not reliable. Oh joy! Fun part is, I have a Tundra with similar miles on it, and it has the same engine, so I might be needing to change that one too. Oh joy!
After doing that a few times you can probably get that time down to 7-8 hours.![]()
