Recreating the Tech Library - please help with links!
bigwalton
Alaskan Postal nutjob
FORUM MANAGER
Dexter
When we went to the new forum software, one of the many compromises we had to accept was that we lost the Technical Library functionality. (As with everything, that functionality had become problematic, but at least it was there.)
I have started a new, moderated "Tech Library" forum here that should be able to replicate what we had to some degree. It's now the first one in the subforum list under "Technical."
Link: https://www.cj-8.com/forum/tech-library.72/
Only moderators/myself can post there and we have the ability to "Copy" posts (not whole threads, just individual posts) to new threads in this forum. In a way, this is kind of ideal because the original threads aren't affected and we can just move over the specific technical posts, so it will be simple and uncluttered.
I moved @jbeemer's EXCELLENT post about shortening CJ seat brackets there to start it off and now I need all of you to help me build it out further.
The ask:
Post a link to a technical thread/post that has helped you or that you really enjoyed reading. I NEED THE LINK, so please search for it and post in in your reply.
There's no way I'll have time to hunt down all of the threads and do the copying, so I need to spend my time actually copying the relevant posts over to new threads. So if y'all could spend a little bit of time to post the links, I can hopefully chunk out a bunch of new threads in there at a time and we'll build this back up quickly.
The real issue with this is that I can't copy the whole thread, so if the good info spans across multiple posts and pages, it may become too much to deal with, but I'll do my best. With that said, if there's a few posts on the middle of a long thread with a great tip/how-to, this will allow me to pull that out and highlight it on it's own so it's easier to find.
Moving forward, whenever there's a new post/thread that should be considered for the Tech Library, you can simply post and use the "@" tag to tag me: @bigwalton and mention that I should take a look. :thumbsup: So keep that in mind as you browse.
@bigwalton
Here are a few from previous tech library posts for side rails:
http://mfaile.tripod.com/rails/rail.html
https://www.cj-8.com/threads/cj-8-scrambler-wood-rail-specifications.40808/
Post #26
https://www.cj-8.com/threads/cj-8-scrambler-wood-rail-specifications.40808/page-2
We had a tech library? Don't remember ever seeing it..
Yep, if you bookmarked a forum page that you always came to first you would have had to navigate to it. This way of doing it will hopefully make it easier to find/use.
@bigwalton
Of the projects I've tackled with my Scrambler, there were a few that I could find almost no information about....
I did my own build threads, but they might leave a little to be desired!
If you think they might help someone, here's how I swapped an XJ/YJ tilt steering column in to my Scrambler:
https://www.cj-8.com/threads/swapping-a-yj-steering-column-in-to-my-cj8.46271/
And... here's my sadly photo-starved Rock-Hard in-cab cage install:
https://www.cj-8.com/threads/cab-repairs-rock-hard-cage-install.49067/
I hope some of this is usable! :shrug:
Not trying to take this in another direction, but there are so many good treads (or portions of builds) that if a table of content could be made. Something like a heading (ex. Waren-full-floating-axle-installations), then a list of links (even if it's a link that's one page of build tread), that would be awesome. I know it would take forever, with all the good info scattered through the forum, you could build a jeep off the info. it you could find it all. A shame it can't be done.
Go for it ;)
@bigwalton
Also, there seems to be a resurgent interest in the Warn style axle conversions. Here's my full-floating axle write-up:
https://www.cj-8.com/threads/warn-full-floating-axle-installation.48281/#post-394336
Embedded is a link to Spankrjs' install, which covers things that mine doesn't.
Also, Spankrjs has a good front hub swap, for which I'll find the link. I've got the parts, and will do it myself sometime this spring... but I haven't done it yet. :wave:
Got it and I think I already have the other front thread you mention.
