My First Scrambler
What products and buffer are you using? Looks great
Thanks! I use 3M Perfect-It with a foam pad. Its a slow process to polish the paint without cutting too much or burning it. I probably go over every panel 6-7 times to get it the way I want it. I remove all of the flares, reflectors, etc so I can get to the paint behind them.
That looks fantastic. Pictures of the product or products you used and pad? I google searched the 3m perfect and found a 3 step process. Are you using all three steps? All original paint should be saved!
Thanks. I personally use a Milwaukee buffer, along with 3M Perfect-It step 1 and step 3. I use 3 different foam pads, the heaviest cut for heavily oxidized surfaces (like mine), a medium cutting pad, and a polishing pad to finish.
For my particular application, I used the heavy cutting pad along with 3M step 1 for about 7 applications. Then I came back with step 3 and the polishing pad to remove any swirl marks. Its a long slow process, but the results are what I wanted. This Scrambler looked like it had never been waxed its entire life, so it took more time and effort than normal.
I have been personally buffing/polishing my own cars for over 30 years, so I do have a little experience at it. The process for newer cars and black vehicles would be a little different combination of the 2 products and the 3 pads.
What I normally do is I start with one panel, maybe the hood, and do some test buffing to decide which combination of pads/compound I am going to need.
I have about 20 hours in the entire process, but I take one panel at a time and work on it until I am satisfied with its finish and gloss, and then move on to the next panel. I may spend 1/2 hour on a panel, I may spend 2 hours, but I don't move on until I'm satisfied with the results.
Hope this helps, I can post pics of the pads and buffer later today.
The tie rod needs straightening/replacing and probably some of the U shackles at some point.
Minor stuff really, great find.
Great looking Srambler. Welcome.
I can say I have no experience with a buffer or pads so I would like to see those. Also have probably only waxed my CJ 3 times in 35 years. Luckily it has been in a garage the last 30 years so the paint is in fair condition / patina.
