That looks fantastic. Pictures of the product or products you used and pad? I google searched the 3m perfect and found a 3 step process. Are you using all three steps? All original paint should be saved!
Thanks. I personally use a Milwaukee buffer, along with 3M Perfect-It step 1 and step 3. I use 3 different foam pads, the heaviest cut for heavily oxidized surfaces (like mine), a medium cutting pad, and a polishing pad to finish.
For my particular application, I used the heavy cutting pad along with 3M step 1 for about 7 applications. Then I came back with step 3 and the polishing pad to remove any swirl marks. Its a long slow process, but the results are what I wanted. This Scrambler looked like it had never been waxed its entire life, so it took more time and effort than normal.
I have been personally buffing/polishing my own cars for over 30 years, so I do have a little experience at it. The process for newer cars and black vehicles would be a little different combination of the 2 products and the 3 pads.
What I normally do is I start with one panel, maybe the hood, and do some test buffing to decide which combination of pads/compound I am going to need.
I have about 20 hours in the entire process, but I take one panel at a time and work on it until I am satisfied with its finish and gloss, and then move on to the next panel. I may spend 1/2 hour on a panel, I may spend 2 hours, but I don't move on until I'm satisfied with the results.
Hope this helps, I can post pics of the pads and buffer later today.
