World Cab Retrofit Project
I’ve got a bunch in the postal top, was thinking of just welding those holes shut. Definitely gonna use them or repops in the overlander just for originality.
Been decades since I heard of someone using Naval Jelly. Looks like it cleaned up well.
I used naval jelly in the 1980's on my first Jeep as a teenager. I used it yesterday to take rust spots off a tilt lever! I use it with steel wool to take off rust spots on all my chrome parts: wagon wheels, bumpers/bumperettes, tilt/turn/shift levers, etc. Still works great.
I grew up in a very salty area which created quickly, metal rusting in no time. Even low quality stainless with in a week would start rusting. I remember my dad in the late 60's and early 70's using it to fight this battle. :) It was a no winning war.
Oh, and that is a heck of an investment in evaporust!
Yeah, but I've got other things I can use it on also. One reason I elevated the long tub is so I can drain the evaporust back in to buckets.
I've been throwing some old tools in there with the body panels, and they come out nice and shiny! ;)
I believe it doesn’t get “used up” right? Seem to recall that from their booth talk at SEMA a while back. You just re-store it and use it over and over?
Unfortunately, it does get used up. Evaporust is a chelation process and once the ph of the solution starts to drift it will leave a black layer of "something" on the part and the solution will become less effective. This black layer can be stripped with some effort, but best to just avoid it by not submerging the items for too long or trying to use the solution past the saturation point. I have used it successfully to bring tools (many small vices, spanners, and clamps) back to life after being submerged in flood waters (Tropical Storm Allison). After enough rust (iron) is in the solution it just looses its effectiveness.
Another cheap chelation agent is molasses. Get some industrial grade molasses at the local feed store, and dilute it 10:1 with water and leave the part in it for a lot longer (days, if not weeks depending on the severity of rust). It just does not work as fast as some of the other commercially available products, but is about 5-10% of the cost of the commercial products. (Not sure I would use that on the double wall world cab top though, might be hard to flush it out from between the panels. And the idea of molasses in my jeep just does not sound appetizing.)
That seems like an incredible product - never heard of it before. I just did a few searches and from the youtube videos I found, they claim that 1 gallon can treat up to 300 pounds of metal, and it won't lose it's effectiveness until it turns completely black. Albeit, that was from the president of the company (
I'm interested to hear your impressions of the product, and watching this project closely!
Hoov
I've heard of navel jelly but never actually looked for it. Where does one find it?
It does wear out eventually, but it can reportedly be re-used quite a few times, depending on the amount of rust removed.
I'm impressed with how quickly it works! My previous de-rusting efforts have been with small parts/tools in white vinegar, which works very well, but usually needs to soak for a couple of days. Vinegar is an acid though, and I didn't want any of it to be trapped inside the cab walls.
Muriatic acid is supposed to work well also, but that's a little more than I want to deal with in my driveway. :crazy:
Here's the longer "tank" for soaking the sides, made with lumber from Jeepaddict's shipping crate. :thumbsup:
It worked out pretty well! There are a few spots that didn't get submerged, but I can can clean them up using Ag4ever's paper towel method, or with naval jelly.
Clean metal makes close inspection a lot easier. There are few blemishes, some of which I'll address now, and others that can wait indefinitely (my Scrambler isn't perfect, so the top doesn't need to be perfect either).
Here's something that needs fixing, though:
That's where the upper barn door hinge bolts on, and there's some pretty good cracking around the top. I'm guessing it's a result of a heavy spare tire, which I will not be mounting to the door. There's no easy way to access the inside of this panel, so I think the best I can do is weld up these cracks... any thoughts?
I'll practice on the door shells first. They have cracks in the usual places, so I can use them figure out my welder settings.
If I recall correctly the thing to do on those cracks would be to drill a small hole at the end of the crack to prevent spreading, and then weld the whole thing up and grind it smooth.
I've used a lot of this stuff trying to clean out rusted steel Honda ATV gas tanks. Vinegar works, but takes a while. Muriatic acid is actually a bit too aggressive, works instantly, but the metal will flash rust in seconds. Evaporust works well and tends to no re-rust as easily, but is pricey.
All of them you are best suited to neutralize with some baking soda/water or the metal will flash rust again from moisture in the air.
If looking for evaporust, my local Harbor Freight sells it, so I assume most of them have it if you have one local(I got one less than 2 miles away which is nice if I need a low priced tool)
Dang, my Harbor Freight is only two blocks away, and I never even checked! :banghead:
Anyone have blueprints or technical drawings of the World Top? I'd like a hard top across just the top, not necessarily the sides or back door. I really just want to keep the rain of our heads and the sun from baking our brains.
I have been noodling on just forming my own top but if there are already drawings out there that will save me some time and starting from scratch.
I don’t see this saving you time. The bottom of the roof panel isn’t flat and has the upswing right behind the front doors that would look odd without any sides and is essentially unneeded for what you’re talking about, it would just complicate everything. Just my thoughts.
I wouldn’t try to do it as a solid panel either, a lot of weight up high to try to secure where a long bikini would serve the purpose, right? I’d work with a canvas company using some soft top hardware if it were me. :shrug:
There are some nice isometric drawings in the illustrated version of the parts catalog. I am not home to get out for you. I believe it’s been captured here somewhere tho.
