Been looking at 76-78 F100 for the high pinion.
I've spent some time researching the same idea, I also would like to go wider. I'm just going to go with a new bear front housing from Custom Axle Design to my specs and build it up myself. For the rear, I'll just cut another ford 9 inch down.I've come across a pretty good deal on a set of 44's off a 70/71 Scout. What are the big differences between the Scout 44's and Wagoneer 44's when installing them? Thanks in advance for the input!
You better jump on that if you're in the area!What do y'all think of this deal??? Seems almost too good https://www.facebook.com/marketplace/item/1330034100481004/
DO IT!I’m in Raleigh, but it’s almost too good to not drive down there
The ad states they are stock Jeep width formally on a Scrambler.Wonder if they are stock width?
Looks like a smoking hot deal
) with a lot of grinding. The front is clearly not ready to bolt in as someone went in and cut off the perches, so these weren't just pulled out from under a Scrambler and put up for sale.
