- Biloxi
- MS
One other thing i found interesting:
I knew that the SolVac would do the "two step idle up" thing on a hot restart, it does it all the time. Basically, 45 seconds of "vacuum sourced" high idle, followed by 15 seconds of "electric sourced" high idle, then it drops to curb idle. Depending on how you adjust the SolVac, the idle on a hot restart goes: 1100 RPM for a bit, 900 RPM for a bit, then drops to 680 RPM base idle. I could be wrong on the time on each stage, but 60 seconds total.
Also, if you have AC, or ground the AC wire, the electric portion of the SolVac holds the idle up to compensate for the AC compressor drag. The electric portion won't overcome the throttle spring, BUT the vacuum portion will.
What I have noticed in the past, and never knew why: sometimes, after slowing down quickly from high speed driving, the idle would be up a bit for around 10-30 seconds. Now I know why, the SolVac will come on line during/after deceleration sometimes. Why, I don't know, but it does.
