- Franklin
- TN
I recently had a Holley EFI kit installed on my 85 CJ8 and when I drove her home, the OEM Voltmeter and the new digital Holley "dashboard" showed that my Jeep was pulling 17.4 Volts.
It is in "learning mode" and I didn't realize how high the volts were until I checked about halfway home from the shop.
So, this morning, I checked the volts @ the battery = 12.6V
Alternator = 12.6V and Battery/Block Ground = 12.6V
But once I started the Jeep and let it idle, the Voltmeter showed 16.9V at every location listed above.
So, I checked a couple of other things and took it for a drive around the neighborhood and the volts started coming down to 16.2V. I confirmed that at each location above at idle with my Voltmeter.
So, the new EFI is still in "Learning Mode"... could it be pulling too many Volts as it learns my Jeep?
I contacted the shop and the owner was very defensive and said that my alternator must be bad.
I never had Voltage problems before the EFI install AND this same shop, which is an "certified installer" put a Sniper EFI kit on my Dad's 48 Chevy at the same time as they were working on mine and his had a hot short and didn't even make it home. They rewired it today but claimed no responsibility and charged my dad for hunting down the issue.
So, I don't have much trust in them now. Especially after issues with my Dad's install.
What do y'all think? Are there any other tests that I can do to troubleshoot? Should I replace the alternator?
Please help! I don't want to take it back to this a-hole unless we can pinpoint where he messed up the wiring.
Thank you in advance.
especially if I'm reading this right and you swapped tanks.
