Seat Options - reclining ? Maybe heated?
cneglia
New member
Stanhope
NJ
Ok I am sure this has come up but what will fit in my Scrambler once I put the full soft top on. I would like to just mount my current seat brackets easily nothing that needs welding. Heated would be a bonus but at least reclining.
I have a pair of Mastercraft Baja RS seats in mine that I put in the $25 seat heater kits and it is awesome! You can buy the seats with them installed too. Heated seats are the best thing since sliced bread- It'll be money well spent.
Don’t most reclining seats in a scrambler foul on the stock roll bar due to the larger size?
I don’t have first hand knowledge on this, just what I have heard from others.
So, I just installed some best top premium seats. They did hit on the roll bar when I tried to recline them. I had to drill new holes in seat mounts, and move them over toward the center of the jeep In order to solve this problem. I also had to cut the factory seat mounts down a couple of inches to lower them. The passenger seat was a little tricky because it’s a folding mount.
I also Had to add to the flange on the folding passenger side seat mount, in order to move the seat over. I just weld a piece of flat bar to the existing flange.
I absolutely love the Corbeu XRS suspension seats. Feel like I’m sitting on a cloud. They have some great side bolsters to lock me in. Easy bolt on to factory brackets. Easy to remove the cover and install a heater too. https://corbeau.com/baja-xrs/
Are any of you running a center console, if so, how wide?
I was hoping to get some decent seats AND a 12.5" Tuffy console in mine.
I’m running a 6.5 inch tuffy in two of my jeeps. It gives you a little more room.
8” Tuffy in mine with Mastercraft seats. A wider console would be difficult and very tight.
This console is custom but 10” wide. Seats rub 7CCEAD86-F259-4B50-B1EE-289BC1C2C6BC.jpegpretty good but no problems. The Corbeu seats recline pretty far. There is a harness bar they are up against in that picture but if it wasn’t there, they would recline quite a bit more.B6F7DB31-C4ED-44F8-9BD9-2A0E637AE24D.jpeg
This console is custom but 10” wide. Seats rub pretty good but no problems. The Corbeu seats recline pretty far. There is a harness bar they are up against in that picture but if it wasn’t there, they would recline quite a bit more.
That console is nice - good job on that!
Are those the Baja XRS seats?
Thanks! Which Master Craft seats do you have?
I’ve had them for years, but I think that they’re the Rubicon seats. Non-reclining, but they’re comfortable and there’s no room for them to recline if I wanted them to.
