But note that you aren’t likely going to install it as they came from the factory. I wouldn’t worry too much about finding an exact replacement. You basically have to do whatever you can to get another nut of the right size held in place there.Technically they are called weldnuts. They usually get presswelded ( resistance weld) into place. We use them all the time in our business here. Check with you local fastener company.
Yea that's what I was thinking, be hard to get a mig on it. I thought about just cutting a square piece, drilling and tapping it, sliding it in the access hole, maybe drill two 1/4" holes in the top of the frame and plug weld it thru there. That way it couldn't move when you tightened it.But note that you aren’t likely going to install it as they came from the factory. I wouldn’t worry too much about finding an exact replacement. You basically have to do whatever you can to get another nut of the right size held in place there.
It's really solid, I'm really impressed with it's lack of rust. I think it will be fine, I have some cracks to weld up and some of the very poor factory welds need going over. I kinda thought this was what I would do from the beginning but I like to ask questions on here like this, never know if someone has found a better way.I’ve just welded a nut to a piece of strap steel and gotten the bolt started and then cranked it down. You have to be able to hold the steel while you start it though.
I like your plug weld idea as long as you’re confident in the surrounding frame steel and that you’re not creating a weak spot in the frame.
