YJ Half Door Alignment
scgator
Member
Mount Pleasant
SC
Hi - New to the scrambler family as i just purchased my first CJ-8 ('81). Have a question on the alignment of YJ half doors as mine came with two. The gentlemen before me who did most of the restoration/mods had installed a new tub and when i have oem full doors on they align perfectly with where the lock striker is installed. It also came with YJ half doors but the the lock mechanism is about 1 or 2 inches above the striker. I assume that is just because of the model difference? If so how do I modify the doors to fit as I would much prefer half doors to full? Sorry if there are a bunch of other threads on this, I didnt have much luck searching for them!
A couple updates/notes - I see threads on doors fitting seamlessly so it makes me think the striker plate on my tub is off? The doors are half doors are off a '89.
Isn't the early door latch different from the pin-striker that is common on later CJ's and YJ's?
Early full hard doors with the outside arm handle latch different than the later full hard doors with the paddle handles. Half hard doors should latch the same as the later full hard doors. Got some pictures?
Your reproduction tub isn't like the original ones, but it does seem like the striker pin could be in the same position since the hard doors latch. For there to be 1 to 2 inches difference in where that pin needs to be for the half doors doesn't make sense. Could the door latch have been moved in the hard doors to match where that body pin is located?
The post for the door striker is mounted way different than stock. It should not be mounted directly to the body, but to a triangle mount that is mounted inside the body tub.
Not sure how your full doors are working unless they were modified to work with the bodger body striker.
Thanks for the replies!! It’s seems as if my tub has two layers of steel (exterior and interior) as compared to the original. I think I would have to cut into the interior layer of steel to set the oem striker and mount. Could it be possible the door mounts are off tilt that much? Below are a few picks of my full door latches. Doesn’t look like they have been modified.
I don't have full doors on mine - but by looking at the parts manual the cover plate for the latch is different - the cutout for CJ7-8 should be more central - or upwards than you have
Wonder if your full doors are from something else - Commando?
Definitely not a Commando, doors are not interchangeable between CJ and Commandos. Here's what my 67 JC doors look like. Not sure what's going on, as mentioned the striker pin is not correct, but the YJ doors should drop right on a CJ and work as long as they both are hard doors. 20211005_190148.jpg20211005_190158.jpg20211005_190205.jpg
Here are some more photo from my garage crew.
Note that the striker mount is not bolted to the outside skin, but the body reinforcement. The seatbelt lower / outer mount fastens to this as well.
The tape measure shows the approximate dimensions on the stock door for the cover plate to striker opening. These are square glass doors (postal / overlander / CJ-10), but the striker is in the same place for standard -7 & -8 CJs.
I assume you have an MD Juan tub? If so, there are several people around here that have more experience with them. (I have zero experience, but have one of their cowls in hand that will be installed on one of my Jeeps in the future.)
Ok - I am an idiot and never tried the passenger side door... and what do you know it fits! So I measured my striker bolts and the passenger side sits about a 1/2 higher than the driver side. That could be my issue but I also noticed the door brackets on the passenger side are snug as compared to the driver side the top bracket has about a 1/4 inch gap... I think I may try to adjust the door brackets to make up for the gap becuase it looks like the door could definitely be lowered at least a 1/4 of an inch if not more. If that fails i guess i will try and relocate my striker bolt on the driver side. Will post pics below.
As for the tub, I am not sure on what kind I have. All the ones I have seen have removable tailgates and my tailgate/rear is unfortunately solid. Would love to know if anyone has an idea. It seems like a solid tub.
Thanks everyone for chiming in... This is a new adventure for me.
