1985 4 cylinder Base Model CJ-7
Belizet's carburetor might have been original, the choke was pop riveted shut. I had to remove two rivets, drill and tap, then find two #8 machine screws.
His needle seat assembly had this nifty screen on the fuel inlet side:
And magic of the internet, carburetor rebuilt and installed:
While swapping carburetors I also noticed this:
This is the inlet at the base if the carburetor for the PCV line. Melted on the outside, plugged on the inside, would definitely cause some excess pressure/blow by!!!!
The PCV/fuel vapor vacuum lines are the only lines under the hood in bad shape. All of the smaller lines are still in OK shape.
Jeep started right up, ran pretty good. Until it died, again. This happened the other day and I just left it in the yard where it shut down. Today it happened a mile from the house and had to tow it back. But, both times it did this it is choking down, exhaust is blowing out the front of the cat where the down pipe is rusted.........
Worked on the exhaust next, mainly because I have a pretty strong suspicion. Besides dieing, the engine would not rev much past idle, either underload or just sitting there. And, no exhaust coming out of the tailpipe. So, cut the downstream air tube off the catalytic converter, pulled the tailpipe, muffler and cat off.
What's that in the down pipe?
Yep, pieces of the catalytic convertor!!!
And when I tapped it out on the ground, it is destroyed/plugged up solid!!!
I was 99% sure this was an issue due to all the rattling coming from the catalytic convertor, kind of sounded like a cow bell at idle. Thought about leaving it like that since I am Mississippi State alumni, but it finally plugged up solid.
So, need to pull the down pipe off next and start reconstructing the exhaust system. After pulling the convertor off the Jeep started right up and revved/drove around just fine, just loud.
And one other reoccurring issue bit me again today, dead battery. Pretty sure the ignition switch is on the way out, so will swap one of those in soon, too.
Will leave it in the yard, back on the battery charger (battery disconnected), that's it for now!!!
My CC was clogged fairly early on also. Gutted it and put it back on for some time, eventually getting all new exhaust system.
This one only has 70k +/- on it, but I am sure dumping raw fuel into it due to the over rich/messed up carburetor did not do it any favors. The catastrophic back fire which blew out the muffler was probably not too healthy, either :rotfl:
I love the below picture. I was able to remove the O2 sensor, upstream air pipe, and both exhaust manifold to down pipe nuts without breaking anything. I did this by loosening everything while the engine was running/hot.
I was very happy that the upstream air pipe came off without too much drama. All of these parts are in good shape/functional so no use in just destroying them.
So very happy to have all the original exhaust system components removed. Very upset that not one of the "direct replacement" exhaust system components will work!!!!
Starting at the front, this down pipe is not even close. Too long, wrong angle at the manifold end, and the upstream air injection port is facing the wrong way, 180 degrees out!!
The catalytic converter is a bust. Way too short, wrong sized inlet/outlet, air injection port will not work with OEM without a lot of reducers.
The muffler is too long, but I can make it work.
I mentioned this previously, but this tail pipe is not even close.
I almost threw in the towel, but decided to work through it, and work with what I have.
Broke out some tools, got to work salvaging the OEM components, which are actually in pretty good shape.
The only problem with the front pipe was that it rusted out at the very end where it slid over the catalytic convertor. I simply cut about 2" off, can adapt/modify to work, or cut shorter if needed.
On the tail pipe, I simply cut it off the old muffler. The tail pipe slid over the old mufflers outlet, it will fit inside the replacement muffler. Whatever, I'll take it. Not sure if this is 100% OEM, appears to be welded on? Whatever the case, I can make it work.
No cat, no problem. Two 18" extensions, couple of clamps, voila, 50 state emission illegal catalytic convertor!!!
Reattached the front pipe, slid in my temporary catalytic convertor, then the muffler, and finally the tail pipe. Barely snugged the clamps so I can easily disassemble it all again when I get the correct catalytic convertor. It all bolted together easy and the original tail pipe fits great.
Quick test drive, runs excellent!!!
I have a vacuum leak either with the new carburetor or an emissions/vacuum line that causes a loud whistle. I need to find/repair this before proceeding with any carburetor/Sol-Vac/idle adjustments. Exhaust sounds good, no excess back pressure, and besides a loud whistle, runs great!!! This little 4 cylinder will break the rear tires loose on concrete and will catch third gear on the pine straw in my yard!!! It has good power, very responsive. It is not what I expected at all, especially if you believe the "internet experts" . I still prefer my 6's for my uses, but I would not pass up a good running 4 cylinder CJ.
So, some more engine/exhaust work before I move on to the brake system.
A final word about exhaust system parts. The tail pipe and front pipe I ordered said they were for a 4 cylinder application. They do not match OEM 4 cylinder components at all. Unfortunately, I presume there is not much demand for 2.5 components as opposed to 4.2 parts. And in many cases, 4.2 parts do NOT cross over to 2.5 powered models.
On the catalytic convertor front, it appears Magnaflo makes a "direct fit" part, part #23222 for 49 state emissions models. Will work with 4 or 6 cylinders. Does not match OEM in size or appearance but should be much more easily adaptable.
As for the front pipe and tail pipe, the same numbers also are listed for 258 powered CJ7's.
I was going to return these items, BUT they will work on another 258 powered project I have, and I will need them, so back inside the garage they go for now.
The tailpipe is an almost identical match to the rusted off original below it.
Not the best picture, but the front pipe in the bottom of the picture posted above, matches up with a 258 front pipe:
These parts will eventually find there way on to this project:
One project at a time, so back to work on this current 4 cylinder project.
That's it for now :wave:
Decided to swap out all the original vacuum lines today to help eliminate/find any leaks or problems.
Tools of the trade/supplies:
The routing on this Jeep was correct, so just a matter of swapping in new lines. I take it one piece at a time, slice the old rubber before pulling it off the fittings to prevent damaging the old plastic tubes/nipples.
For example, below is the PCV line assembly (also has hoses that go to base of carb, vapor canister, Decel Valve):
I need to remove the PCV shutoff solenoid and install a straight piece of hose here, there was a service bulletin to remove it.
All the hoses look like this, cracked from age, kindy of sticky/gooey:
This one had part of it's inner liner plugging it up:
New PCV hose made up, ready to install:
About two hours later, all the vacuum hoses replaced, leaving this pile of old hoses:
On the passenger side, all of the vacuum hoses are these plastic/nylon tubes. They all were in good shape, including there little rubber ends. The vacuum canister is still intact and functional:
This was a good exercise to work through, hard to diagnose other issues if you have a bunch of vacuum leaks. Unfortunately, upon start up, it would seem the leaking throttle shaft on this 2nd carburetor is even louder then before, super loud/shrill constant whistle that will only go away at about +30% throttle:
The screw driver is pointing at the vacuum leak source, top of the throttle shaft. I did take it for a drive, but unfortunately, after about 1-2 miles of driving the brakes are wanting to stick. So, I need to address the sticking/nonoperational rear brakes before any more test drives. And obtain a third carburetor.
That's it for now.
Sorry to hear the carburetor did not work out.
It was worth a shot :thumbsup:
So thank you again. Even though the throttle shaft leaks, the rest of it is good to go. I MIGHT try to install new bushing, but the plastic covered throttle shaft has me concerned about my odds of success :shrug:
Wondering if why that’s why my buddy and I could never get mine working well. Just ran like a gutless wonder. I read about Weber having a carb. that might work and it was an easy conversion. Installed and never looked back, and vastly improved performance and power.
Maybe so. When I drove this Jeep with your carburetor, before the brakes started sticking, it wad not as peppy as with the other damaged carburetor. Your old carburetor has a hell of a vacuum leak at the throttle shaft, so I am fairly confident that unmetered air is having an affect. The loud whistle sound also makes all animals cower in fear!!!!!
Taking a brake (get it!!!) from working on the "GO!!", to work on the "WHOA!!!!" (I crack myself up)
Nice weather, going to make a mess, back in the yard where I belong!!
Before the complete brake system malfunction, this thing actually stopped well, no pulling or other issues. The brake warning light is on, back brakes are non-op, and the front calipers finally started sticking to the point of the front wheels smoking after short drives. Time to get to work.
Front brake pads passenger side, inner pad almost non-existent: (driver side is on right, look at how thick pad material is vs left pad!!!)
And the driver side, the same but worse, the inner brake pad rivets destroyed the rotor:
This was obviously an issue before JeepAddict bought this "rust free, just pump the gas pedal three times and starts and runs like a champ" Jeep.
Driver side, rear brake, broken parking brake cable, brake shoes still have a little meat:
Passenger side, rear brake, brake shoe thickness OK:
Almost looks like someone changed the passenger side brake shoes, but not driver side? Who knows. With only 70k miles, might be the original brakes?
I am pretty sure both front brake lines are restricting the flow of fluid back upstream, causing the calipers to drag. The fluid that came out of the calipers was nasty, so, let's snowball this project!!!!!!!!!!!!!!!!!!!!!
Change all three rubber brake lines
New calipers, rotors, pads on the front
Since the front wheel hubs have to come off, new wheel bearings, hub seals, spindle bearings/seals, and front axle u-joints just for the hell of it!!
Rear shoes, wheel cylinders, and all drum brake hardware (drums look good, will measure to verify, will probably reuse, no bad lines or damage)
New master cylinder (old one was empty when Jeep Addict received it, except for some thick sludge) (no fluid leaks now, who knows?)
BEFORE adding any new parts, flushing/blowing out all the existing metal brake lines to get rid of gunk/moisture/debris
Luckily for me, no rear axle seal leaks, rear wheel bearings feel/rotate fine, so at least the rear axles can stay installed!!!!!!
All my parts should arrive tomorrow, so at least I have something to keep me entertained the next few days!!!!!!!
That's it for now:crazy:
Piddled last night, got the two front flex lines off, but it was a fight!!!!!!!!!!!!!!
Passenger side came off with a little heat. Driver side took 5 minutes of MAP gas torch before it would break free. No damage to the steel lines, so happy about that.
Fluid looks nice!!!!!!!
And chunky!!
The calipers had fluid and crap inside of them when I removed them. The master cylinder is still full, but not much fluid is coming from either front chassis hard line. Pushing the brake pedal down will cause fluid to come out of both front lines.
Before I cut the rear hose, I hit the brake pedal. No drums, shoes, nothing on either rear side. Wheel cylinders did not budge. Cut the rear hose, nothing leaked out. Ran a piece of tie wire in and out of the rear flex line, finally some dribble. Refilled the master cylinder, going to let it "gravity/self flush" a few times over the next few days.
The front brakes did work. The rear brakes have never worked. Previous owner had disconnected the wire plug from the proportioning valve. I plugged the wire harness back in a few weeks ago, the "Brake Warning Light" has stayed illuminated ever since.
I am hoping the proportioning valve is good to go. I will let the hard chassis lines "gravity flush" over the next few day, before installing a new master cylinder and reconnecting all of the other brake components.
Hope to successfully remove the rear rubber flex line, and both axle mounted hard lines tonight.
I am fairly confident that all three original rubber brake lines were deteriorating from the inside out. The exteriors of the hoses looked fine, but the rear line was completely collapsed (inner liner broke free from exterior jacket), and both front lines were partially blocked.
Not exciting, but that's it for now :shrug:
Used the torch on all five fittings, all five broke free with no damage, happy dance time 💃
The driver side rear line had fluid in it, passenger side was dry/plugged. Was able to clean out the two axle mounted lines for reuse. On my second brake fluid flush on the rear line. Cleaned the brake backing plates, ready for reassembly once I pick up all the parts/get some spare time.
That's it for now:wave:
NAPA Clause came to town:
Installed wheel cylinders, shoes and all associated hardware this afternoon:
Still need to swap master cylinder, reconnect hard/soft brake lines, install front brakes, plus disassemble/assemble everything on the front axle from the u-joints out.
Worked on this one most of the day.
Noticed the driver side brake pads did not want to sit right. Turns out the driver side parking brake/cable was partially frozen engaged. Pried it back off. All three parking brake cables are frozen up. I put some lube on them but am not holding out hope for them.
Anyway, brake drums installed, brakes adjusted.
Installed the rear soft line, and both axle mounted hard lines, after cleaning/flushing the brake lines out, again.
Went ahead and installed the two front flexible lines, after flushing out the hard lines, again.
Removed the old master cylinder, installed a new one, bench bled it in place.
This is the worst part about changing out a non-power brake master cylinder, the little cotter pin that holds the arm to the brake pedal. Took almost an hour to get the old one out. I always install this style clip, will be easier for the next guy!!!
Removed the lock in hubs, rotor hubs, splash shields, spindles (and removed spindle bearings), and both front axle shafts. Old spindle bearings weren't too bad, wheel bearings OK, front axle shaft u-joints a little stiff. I will be swapping in all new bearings/seals/u-joints/rotors, hopefully tomorrow.
Left it like this for the night:
:wave:
