- Biloxi
- MS
Belizet's carburetor might have been original, the choke was pop riveted shut. I had to remove two rivets, drill and tap, then find two #8 machine screws.
His needle seat assembly had this nifty screen on the fuel inlet side:
And magic of the internet, carburetor rebuilt and installed:
While swapping carburetors I also noticed this:
This is the inlet at the base if the carburetor for the PCV line. Melted on the outside, plugged on the inside, would definitely cause some excess pressure/blow by!!!!
The PCV/fuel vapor vacuum lines are the only lines under the hood in bad shape. All of the smaller lines are still in OK shape.
Jeep started right up, ran pretty good. Until it died, again. This happened the other day and I just left it in the yard where it shut down. Today it happened a mile from the house and had to tow it back. But, both times it did this it is choking down, exhaust is blowing out the front of the cat where the down pipe is rusted.........
