CJ8 on a JL frame?
gr8dain
Old and Slow
Ashburn
VA
Am I crazy? I picked up a 1981 Laredo last week and the frame is in rough shape. A friend has a JL chassis for sale with suspension and wheels. I know the HL is 3.1 inches longer in wheelbase. But I don’t think that is a deal breaker. Checking on other dimensions of the frame now. Would I be crazy to put a Scrambler frame on a JL?
Sounds cool… Here is an thread on JK https://www.cj-8.com/threads/scrambler-on-a-jk-unlimited-frame-build.44502/
I did this frame on my Cj8
A few thoughts from frame swap…
Axle 66.5” to 68” wide on JL vs 56” wide track CJ. will mean tire stick out 5” on each and depends on wheel back spacing.
Wheel selection is tricky because of backspacing needed to clear steering knuckle
Steering options get tricky on location of steering box.
Shock towers on JL front might require inner fender trim, not sure about rear.
Body mount on JL frame likely in wrong location and too wide as the body is about foot wider
Likely others have thoughts and anything is possible with imagination, time, skills and money. Look forward to seeing your next steps, well wishes
Yeah, the width had me questioning it. I got two diagrams with measurements for a JL frame and a Scrambler frame. It will take some serious adjustments to make it work.
Why? To sell? You just built yours into a great DD. Why get into all of this?
What drivetrain are you going to run? I would think trying to make that drivetrain with computers work in a scrambler is going to make getting the 4.0 running look like installing an LED light.
Agree....too much work, I think you should just pass it along to me as I have a restored frame and no good tub. :thumbsup:
Truck
I would only do it if you want something that rides like a modern vehicle on road and is great offroad. In all seriousness I would love to see this built. The JL axles are pretty descent right from the factory. 35" tires with factory wheels will be about 75" overall width.
My choice would be LS with a 4l60E or 6l80 to a drivers drop 241C with the SYE. Save the headache and buy a standalone engine/trans harness. Last one we did on a scout was like 5 electrical connections.
Now the less fun part. Develop a realistic budget and decide if this project is something you want to take on.
I am not sure what I was smoking last night. I don’t need this in my life. I will probably part it all out. Who wants a propane conversion kit?
I thought about getting a TDK frame. But those are too nice ($$) for me.
Truck
Have you see the pics? The tub isn’t great either.
Yeah, I would probably end up selling it. It was just crazy thoughts because I know someone with a JL chassis he is selling. And it got an LS in my mind.
With the front disconnect?
I see them snapped on the sand dunes often.
LOL, true the disco is definitely their weakest point. The JL is quite a bit heavier. Even with all the benefits of the newer dana 30/44 they still have a few negatives.
Ah, the grand plans we concoct after a few stiff drinks awaken that hidden imagination and drive.
I’m still wondering if I have the initiative to build that Jeepster I bought, especially considering how I’ve been able to complete my Scrambler so quickly. 🤣
Be a neat project. I am just finishing up a YJ tub on a TJ frame. For the tub, I found that the two rear tub mounts were key to line the bed up properly on the TJ frame. There is definitely massaging required. 97 frame and 04 Rubicon drive. Can bus is the next challenge or will go 97 OBD2.
Shop needs a clean out.
Do you have a link for this? How have I missed this?!
I have taken pics but haven't posted. Didn't feel it fit and it has become my distraction...much to the dismay of my wife...it has however allowed me to expirement and learn more metal body work. The 8 will thank me when I refocus on that body.
I stretched a 2000 TJ frame to put a 57 CJ6 body on it. It was work but I got to come out pretty good.
I did an Aqualu aluminum CJ-8 tub on a new JKU frame. A lot of modifications to the tub and frame. I was starting the build from the ground up so I’m not sure if that is easier than not.
Good to see you back on… how is that project?
