PetesCj-8
- slatington
- pa
My daughter has an 2000 XJ with a problem I havent come across before. Initially the Jeep drives fine till she comes to a stop. Then when she pulls out the engine revs and it feels almost like the trans is slipping but its not.
If you manully shift it through the gears it works just fine. The only code it shows is for the crank position sensor and it was only once while this is a persistent problem. Figured Id ask here before taking it somewhere considering theres a couple XJers on here.
