Hub Lockout
TMBRWLF
New member
Stover
Mo
Hello all. New here and looking for a answer on the 4x4 hub lockout. Looking at a Scrambler purchase for our hilly, rocky property. It'll be used most days on fenceline and trails. Possibly in and out of 4x4. Can the hubs stay locked in while in 2wd? Any effects to front axle? There's two I'm considering. 1981 and 1983. One auto, the other manual. Any info is appreciated...
You can leave the hub’s locked with no concerns. They serve to help get a bit better mileage and less wear on the front end components. It won’t harm anything to just leave them locked. Auto vs manual is simply preference. I personally prefer automatic, I’ve got 2 feet and 2 pedals to deal with.
I’d prefer the 83, for the wide track axles. I also prefer an automatic transmission nowadays, since I have a bad left knee. Just my preference.
Thanks John for reply...
I would be more concerned about what rust there is on the body and frame. On the frame look the whole thing over inside and out. They like to rot out near the rear spring hangers because water has nowhere to drain there.
The 81 is the one that had two spots repaired with Frame Buster parts. Not sure yet on the 83...
Assuming they are similar condition, I would lean towards the ‘83 for the widetrac axles.
If being used in a hilly area at low speed, the auto would be easier to drive. If the automatic transmission needs a rebuild, some of the parts are becoming hard to find, others are easy to find.
I personally prefer the manual transmission. Easy to rebuild and maintain, easy to drive.
You can leave the hubs locked at any speed, if locked the axle shafts and front drive shaft will spin from tire speed and as long as you are in 2nd at the transfer case, the difference in speed from front to back will be handled through gear disengagement at the transfer case. If driving at low speeds, leaving the hubs engaged is preferred so you can be ready for 4x4 when needed.
The only time you might want the hubs disengaged is when you want low gear in the transfer case and 2wd. You can accomplish this by leaving the drivers hub disengaged and passenger hub engaged, as long as you have an open differential. That way, if you want 4wd you only need to hop out and engage one hub.
