I'm sure you have one, but if you don't, let me know and I'll mail you my other one!Ill try them. I have to find one now.
Want to make me one? Been looking for a bumper since the shop through my original chrome one away thinking it was aftermarket.The workbench has all the cutting implements on it.. nothing exciting there... but here are all the resultant pieces... modular bumper is back on the list to get done... been too long.
Cut down an old bumper for the mounts... 4 of them.
Mock up
Side views
Not 100% sold on it yet, but it is pretty close to what I had in my mind... a lot of cutting and re-fitting.
Let me know, if it is feasible, I would definitely be a potential customer.When I get this to the place I think it should be, I would consider it... the end caps are from @Kim Dawson and the steel was purchased pre-cut... the places where it will screw together is what needs the most fabrication... and then the connections to the rear crossmember were an old front bumper that I used the unbent side on... and then hardware.
It adds up a lot more than I thought it would be honestly... and I was using some scrap I had lying around.
PS> Sorry to hear about your original bumper... that really sucks.
I sure like that heater. I could really use that right now. Nice garage.Not what's on my work bench... but here is my work bench. I put up a "back splash"
Moved into this house May 2023 and only finally getting everything set up how I like it...
Check out the thermometer on the wall, then I realized it was CelsiusI sure like that heater. I could really use that right now. Nice garage.
It was -20C (-4F) outside when I took the pic.Check out the thermometer on the wall, then I realized it was Celsius
