I have used the warn one. I like it. Has sleeves for the bolts so you don't crush the frame tightening the bolts.This is what II was looking at.
WARN 13910 Fixed Winch Mount Kit, Fits: Jeep CJ and Scrambler (1959-1986)
Thank youI have used the warn one. I like it. Has sleeves for the bolts so you don't crush the frame tightening the bolts.
Cool thanks. I think I'll run that winch plate. It has ears that go down the side of the frame that will replace the shims that were installed for thr reverse shackle. The spring hanger is just what I need if I decide to run the non reverse shackle set up. Since the original hanger has already been removed and a sleeve welded in the frame I will probably try the reverse shackle set up first. I will contact Mountain Off-road to get some shackle info. If that leads down a rabbit hole then I can go back and weld on the hanger you suggest.I have that winch kit on mine as well.
Barnes, RuffStuff, many other companies make a spring hanger for a Yj spring you can weld on, if you decide to go back.
Leaf Spring Hanger for 2.5" Springs
Check out the deal on Leaf Spring Hanger for 2.5" Springs at wfoconcepts.comwww.wfoconcepts.com
What shackle info do you need?Cool thanks. I think I'll run that winch plate. It has ears that go down the side of the frame that will replace the shims that were installed for thr reverse shackle. The spring hanger is just what I need if I decide to run the non reverse shackle set up. Since the original hanger has already been removed and a sleeve welded in the frame I will probably try the reverse shackle set up first. I will contact Mountain Off-road to get some shackle info. If that leads down a rabbit hole then I can go back and weld on the hanger you suggest.
Thank you folks for your info
bushing then a sleeve it won't leave much of a bolt. It appears the original set up didn't use a inner sleeve so it was 1/2 bolt through poly bushing also the poly bushing would have to have large flange to make up for width of YJ spring compare to CJ frame width.The front hangers I have (bought YJ conversion from Rocky Road with OMU springs)If you decided to go back to shackle forward, there are also front CJ shackle hangers that bolt on, that are for YJ springs.
My Silver CJ8 has these in the front, that clear the rivets and steering box, and are YJ width:
With the spring hanger I linked, you'd be pretty factory looking.
I agree with your observation. To add to that when measuring from front of frame to sleeve they are not equal 1/2" different. That's why going back to original (shackles in front) might be the way to go. I could just by pass these and weld on new hangers. The old hangers that were removed I assume were attached with two large rivets. I can see the torch marks.I don't like that sleeve at all, or how it's welded in.
I'd take a grinder to that and get rid of it.
Poor welding, poor execution.
You could go bigger, or at least weld it in correctly.
Yea, if you look at the ones I sent, they have the same bolt holes... and the OEM ones were also welded on the sides.I agree with your observation. To add to that when measuring from front of frame to sleeve they are not equal 1/2" different. That's why going back to original (shackles in front) might be the way to go. I could just by pass these and weld on new hangers. The old hangers that were removed I assume were attached with two large rivets. I can see the torch marks.
You could get rid of those sleaves and plate over them, with fish plates <----> cut like that.
My stock '83 is 43-1/4" from center to center of bolt holes in each mountHey folks.
After input from members and my own pee brain I decided to remove the reverse shackle and go back to a more original configuration. So basically what I'm building is a Rocky Road YJ kit with OMU HD springs. Now the PO had removed the factory rear front spring mounts. One of the members had suggested WFO mounts and my god they don't screw around. Nice choice a question is to mount/weld these mounts in the proper location does any one have a measurement from eye to eye?
