Starting on a journey
Glad your back home safely. Bummer we couldn't connect but In-N-Out is always good. The Grapevine can be a tough climb - especially with the vapor lock issue - you never know when it will stall.
The bridge scene in "Stand By Me" was filmed here in Shasta County at Lake Britton. The serious movie buffs still come visit it to this day.
Get some rest and enjoy the memories of your grand adventure and thanks for sharing it with us!
I'm finally home!
Today was probably the most challenging day of driving during the whole trip. I could have cut over to the coast for some cooler temperatures, but that would have most likely added one more day to the trip and I'd have to deal with bay area traffic.
At this point I was ready to go home, so I decided I could probably get an early start and head straight down the California's central valley and tough it out. Right around 3pm I was regretting that decision. You can see by my location on the map that it was 103 for most of the afternoon, which means the jeeps interior was probably 10-15 degrees hotter. It was so hot inside the jeep that my phone shut down a few times due to the temperature protection. I started having the vapor lock problems even on flat level ground, so I'd have to stop every half hour or so by the exit ramps just to pop the hood and let the engine cool down.
Even if I weren't having the vapor lock problem, I'd probably still be pulling over every half hour because that was about my limit for driving in that kind of heat. I knew it was bad when I would step out of the jeep in 103 weather and breathe a sigh of relief because if felt better than being inside the jeep. Sor for that stretch of freeway which I'd normally cover in about 3 hours, took 6-7 hours because of all the stopping.
I was so focused on making it home that I barely took any pictures. Here's one during my lunch break trying to let the jeep cool off.
And the only other pictures is me stuck on the side of the road going up the grapevine. For those that don't know it's another mountain pass that climbs at a 6% grade for about 5 miles. Not that extreme, but doing it in an old jeep in 100 degree weather is a challenge. I stopped at some outlet stores at the base of the climb to let the engine cool a bit and wait for the sun to go down to give myself a better chance of making it up. In the beginning I was fine, I could manage about 50mph on the initial climb. That slowly went down to 40, then 30, then 25. Luckily I was able to pull in behind some slow semi's that were also struggling to make it up. I got to within a mile of the summit before I stalled.
The jeep's finally back home. It needs a few repairs, but it made it all the way to the Arctic Ocean and back again. There are a few things I'll probably change now that I'm back, and I'll have to solve that vapor lock problem and tie rod, but other than that I'm pretty happy with how it turned out.
Awesome trip. amazing memories and something y'all won't forget for sure. This is definitely the definition of get them out and drive them. thanks for the thread. I'd imagine most normal people would read this and ask why it only makes me want to do a trip just like it.
Awesome. Sorry for the troubles and I know exactly how hot you must have been. The world can is an oven. Ugh.
Grapevine is a haul for sure.
Congrats on a spectacular adventure!
A final recap of my trip. Feels nice to be able to type while sitting at a desk, vs. trying to post stuff while crammed in the back of the jeep balancing the laptop on my lap.
Total mileage ~ around 8600 miles after correction factor applied. I have larger tires so I estimate my odometer is about 10% off
Total fuel - 616 gallons
Average mpg - between 14-15 mpg
Biggest fillup - 27.5 gallons
I'm also going through the pictures my son took on the trip and it's interesting to see the different perspectives of the same trip. On some of the most challenging (and most memorable) moments, I was either too busy, too stressed, or too tired to take any pictures. Since he was a passenger, he was able to capture a lot of things that I didn't.
One of those pictures was while I was trying to repair the tie rod somewhere between Inuvik and Tuk. Notice the Arctic certified footwear (crocs). Aside from the hikes, I was in crocs 99% of the time. Mostly because the weather wasn't that cold and it's easier to slip them on when getting out of the car. Also my windshield leaked pretty bad, so during the rainy periods or when I needed to use the washer fluid, my feel would always be soaking wet. So basically my feet were always wet. Luckily the heater worked exceptionally well and they would dry off pretty fast.
I wanted to visit the bridge, maybe on the next trip up there. There were so many places I wanted to visit but had to pass up due to the lack of time. On this entire trip I only spent 2 days actually in Alaska, most of trip was in Canada. I could have easily spent another month or two just in the Anchorage area exploring the seaside towns.
The good thing about spending so much time in the Jeep is that I got to know it very, very well and you become sensitive to small changes. You start to recognize minor noises, or when it downshifts differently, or how it just feels slightly different when driving. By the end of the trip I actually could tell when it was about to stall and knew how much longer I could keep driving until I needed to pull over, and how long it takes until I'm able to drive again. I also installed a transmission temperature gauge, while it wasn't a direct measure of anything related to the vapor lock, gave me a pretty good indication of how hard I was working the jeep and when I needed to worry about stalling and when I could push it harder.
Now that I'm safely back home, I can say go for it you won't regret it doing it. But to be perfectly honest, I was ready to quit so many times on this trip. During the first day driving up to Nevada in 95F heat and having stalling issues, I thought I'm only a few hours away from home, I could easily turn around and postpone the trip or do it in a much more comfortable and reliable vehicle. I think for the first 2 weeks of the trip, between the heat, the car issues, the rain and wiper problems, there wasn't a single day where I didn't think this was a dumb idea and was going to give up and go home. It wasn't until I was in the Yukon that I started to relax and feel more comfortable with the Jeep.
I was feeling pretty confident in the Jeep, right up until the moment the tie rod stripped. What you can't tell in the picture above was me laying under the jeep for about 10-15 minutes literally just starting at it. No tools in my hand, no plan, just me staring and it thinking WTF am I gonna do? I was 800 miles (3-4 day tow) from anything that could remotely be called city, and more than 1000 miles from Anchorage which is the only major city in that area. I could have even turned around and gone back to Inuvik which was a couple hours away, but at that point I was <100 miles from the Arctic Ocean and after traveling 1000's of miles for a few weeks, there was no way I was willing to turn around. I think sometimes life just throws a bunch of obstacles in your was just to test you motivation to see how bad you really want it.
Looking back, what seemed like major hurdles at the time were really just minor inconveniences. All of the problems might have added an extra 15-20 hours onto my trip, a couple of extra days. I had already planned for some delays because of weather, detours, or construction, so over the course of 5 weeks that additional time really isn't that noticeable.
I appreciate everyone's comments and likes. I did try and read everyone's comments during the trip, but didn't always have time to respond to them while on the road. If anyone has any questions about the trip or the jeep, I'd be happy to answer them
I also wanted the add the jeep was definitely an eye catcher. I met a ton of people on this trip, and most of them were because they saw the jeep and initiated a conversation. Multiple times a day, either at a campsite, restaurant, or even when I was just sitting on the side of the road, people would come up to me to ask about it. In one case along the Stewart Cassiar, a couple of adventure riders slammed on their brakes, made a U-turn and came back just to take a picture of it. I am positive if I had been driving a "normal" vehicle I wouldn't have met nearly as many people.
Thanks for the kind offer. I wish I could have met up, but after dealing with the heat in Oregon I knew California was going to be much worse and drove through the night. I did stop in Redding at the In-n-Out for a late night dinner, but it was still 85 degrees outside, but better than the 103 during the day. I ended up doing a 500 mile day to get through most of it
To back track a little, I didn't make too many stops in Oregon, I got stuck in so much traffic going through Seattle that I tried to bypass Portland during the night and stayed in Corvalis. The next morning I did make a slight detour to a small town off the I5 called Brownsville. It's where they filmed one of my favorite movies Stand by Me. I'm not that much of a movie buff so I didn't intentionally mean to visit all these filming locations, but since I was in the area I had to snap a few pictures.
"The Penny"
If you've watched the end of the movie, they've immortalized the spot with a penny in the street.
We just watched Stand By Me with my 11 yr old daughter last week. First time for her - at least 10th for me. What a great movie.
Congrats on accomplishing something that few would ever even attempt let alone persevere like you did.
