Interceptor
My toy of joy
- Galivants Ferry
- SC
Home sweet home
Awesome trip. amazing memories and something y'all won't forget for sure. This is definitely the definition of get them out and drive them. thanks for the thread. I'd imagine most normal people would read this and ask why it only makes me want to do a trip just like it.I'm finally home!
Today was probably the most challenging day of driving during the whole trip. I could have cut over to the coast for some cooler temperatures, but that would have most likely added one more day to the trip and I'd have to deal with bay area traffic.
At this point I was ready to go home, so I decided I could probably get an early start and head straight down the California's central valley and tough it out. Right around 3pm I was regretting that decision. You can see by my location on the map that it was 103 for most of the afternoon, which means the jeeps interior was probably 10-15 degrees hotter. It was so hot inside the jeep that my phone shut down a few times due to the temperature protection. I started having the vapor lock problems even on flat level ground, so I'd have to stop every half hour or so by the exit ramps just to pop the hood and let the engine cool down.
Even if I weren't having the vapor lock problem, I'd probably still be pulling over every half hour because that was about my limit for driving in that kind of heat. I knew it was bad when I would step out of the jeep in 103 weather and breathe a sigh of relief because if felt better than being inside the jeep. Sor for that stretch of freeway which I'd normally cover in about 3 hours, took 6-7 hours because of all the stopping.
I was so focused on making it home that I barely took any pictures. Here's one during my lunch break trying to let the jeep cool off.
And the only other pictures is me stuck on the side of the road going up the grapevine. For those that don't know it's another mountain pass that climbs at a 6% grade for about 5 miles. Not that extreme, but doing it in an old jeep in 100 degree weather is a challenge. I stopped at some outlet stores at the base of the climb to let the engine cool a bit and wait for the sun to go down to give myself a better chance of making it up. In the beginning I was fine, I could manage about 50mph on the initial climb. That slowly went down to 40, then 30, then 25. Luckily I was able to pull in behind some slow semi's that were also struggling to make it up. I got to within a mile of the summit before I stalled.
The jeep's finally back home. It needs a few repairs, but it made it all the way to the Arctic Ocean and back again. There are a few things I'll probably change now that I'm back, and I'll have to solve that vapor lock problem and tie rod, but other than that I'm pretty happy with how it turned out.
Glad your back home safely. Bummer we couldn't connect but In-N-Out is always good. The Grapevine can be a tough climb - especially with the vapor lock issue - you never know when it will stall.
The bridge scene in "Stand By Me" was filmed here in Shasta County at Lake Britton. The serious movie buffs still come visit it to this day.
Get some rest and enjoy the memories of your grand adventure and thanks for sharing it with us!
We just watched Stand By Me with my 11 yr old daughter last week. First time for her - at least 10th for me. What a great movie.Thanks for the kind offer. I wish I could have met up, but after dealing with the heat in Oregon I knew California was going to be much worse and drove through the night. I did stop in Redding at the In-n-Out for a late night dinner, but it was still 85 degrees outside, but better than the 103 during the day. I ended up doing a 500 mile day to get through most of it
To back track a little, I didn't make too many stops in Oregon, I got stuck in so much traffic going through Seattle that I tried to bypass Portland during the night and stayed in Corvalis. The next morning I did make a slight detour to a small town off the I5 called Brownsville. It's where they filmed one of my favorite movies Stand by Me. I'm not that much of a movie buff so I didn't intentionally mean to visit all these filming locations, but since I was in the area I had to snap a few pictures.
"The Penny"
If you've watched the end of the movie, they've immortalized the spot with a penny in the street.
Your trip inspires a lot of other people thinking that if you can finish this type of trip others can do easier trails. You’ve proven what’s capable with some backbone.
Wow. Now that's a creative solution!A post trip update.
Had some time today to fix the wiper situation. The large washer and spring worked as a temporary fix to get me home, but I think eventually the problem would have reappeared somewhere down the road at the worst possible time.
For those who haven't had this problem (yet), the issue with CJ wipers is the frame flexes too much at the pivots because the sheet metal is too thin to carry the forces on the wipers. You can see it happening if you run the wipers and go outside and watch the base of the wipers, the pivots will rock back and forth on every revolution. This causes overtravel and binding of the linkage, which in turn causes more flexing and eventually the frame gets distorted and the wipers will bind on every revolution and the metal around the pivots will begin to crack.
You can see the outline of the washer where it starts to crease. This is after I straightened out the frame with a hammer and dolly, it was noticeably deformed in that area. The flexing has chipped away the paint in that area.
The large washer I added worked as a temporary fix, but what happens is it just moves the flexing to a different spot on the frame. Instead of flexing right around the washer, the entire area around the embossed part flexes. You can kinda see where the frame has deformed to the upper left of the pivot. In reality, if you watch this area while the wipers are moving, you'll see a lot of side to side movement of the wiper pivot especially at the higher speed.
To fix this permanently I added a brace that goes inside the windshield frame and connects the pivot points together with a stiff piece of channel. Washers welded to either end of the brace keep the pivots aligned and carries the load instead of relying on the thin sheet metal of the windshield frame. The washers have to sit above the brace because of the offset shown in the above pictures.
A shot of the overall setup. The horizontal brace is made of a piece of unistrut. It's probably 10ga material which is way overkill for this, but I had it laying around and didn't feel like making one out of sheet. A piece of 16ga bent into a shallow C-channel would probably work just as well. Also, in this picture the linkages are assembled in the wrong order, the longer one should go underneath the short one. It does make a difference.
Installed in the windshield frame. I had to make a small relief cut in the middle of the brace to allow it to flex a bit. Otherwise it would be impossible to squeeze through the openings in the windshield. Once everything is bolted together the brace flattens out and it doesn't affect anything.
Final result is absolutely no flexing even when the wipers are running on high speed.
Yeah you're probably right I wasn't really thinking about it when I posted, in my mind I was still thinking this is a trip related repair. I'll copy it over to it's own thread with some added details.That deserves it's own thread, I've never seen that approach!
