Turn Signals Issue.
Wayne
Cape Coral
FL
Hello:
Incase anyone has come across this issue before - it will same me a ton of time and I am not a an electrician...
All my lights works - all the bulbs a the correct bulbs all the fuses are the correct size fuses (If the lights work, fair to say the grounds are good)?
I have checked all the grounds that I can find and they look clean and secure.
The Problem.
When turn the left signal on (only the left) all four flashers come on..
When I turn everything off and pull the hazard pin all 4 hazard light will come on.
Would anyone think that the signal arm component is bad?
In the 34 years I have owned the jeep in have only had to replace the signal housing/component once, buyI cannot remember why though I do remember when is removed it, it was cracked.
I appreciate any input - Thank you very much.
Wayne.
When you have the left signal on and all lights flash are they the same brightness as when you only have the hazards on?
Mmmmm - I will check em out.
It was nice and bright out yesterday when I was going over the systems and I did not notice a difference in color / brightness.
Hello again:
I went over the brightness of the bulbs.
If I turn the right signal on, the left will also come on (back & front) but the left is dimmer that the right
Exactly the same if I turn the left signal on.
I have changed bulbs, bought a new flasher, gone over grounds and they look good.
If I'm correct, there are two grounds, both sides of the grill under the hood and the screws on the small signal lights under the headlights and the tale lights are grounded when you screw the bulb housing onto the tub?
The left and right signal bulbs in the cluster
I have taken the wiring connectors apart on the tail lights and re-connected them and the are nice and tight.
I noticed that the left side fender bulbs is week ( they have a sloppy insert) I will probably buy two new fender bulbs tomorrow - not sure if they have anything to do with the issue?
Regards.
Hello again:
When I turn just the 4 way hazards on they seem to be the same brightness as the turn signals.
Regards.
It really sounds like (as everyone has stated) a ground issue.
The power from the battery to the lamps has to return to the battery negative post, if any ground path for an individual lamp is bad it will follow a path through other lamps on the same circuit until it finds its ground.
Typically the lights will be dimmer as the resistance to ground increases as it is now going through more filaments before it finds its ground path back to the battery.
There is a ground jumper under the hood that ties the ground to the firewall - not sure if it is directly from the battery to the firewall or the engine to the firewall- this is the main path for all the lamps (grille, fenders, body and dash) back to the battery.
The front park/signal and rear tail lights also rely on the fixture to body connection for grounding.
Do you have a good connection from battery negative to the firewall?
Are all your front grill park/signal lights solidly connected to the grille when testing?
Do you have a good ground at you rear taillights?
I can't access my FSM right now as it was packed for a move but here is a YT video that may help in diagnosis
I watched that video last week - I was hoping it would help me but other than not having OEM screws for the front signals everything I crossed referenced checked out.
I did check the negative side of the battery- it’s good - clean and tight.
I did look at the ground going from the neg post it goes through a hole in the firewall and is attached securely to the back of the passenger side handle on the dash.
I am going to re-direct tomorrow and see what happens!
I’m confused about the ground jumper under the hood you mentioned..I will need to research that more.
Truly appreciate your guidance.
Cheers.
Negative should go to the frame and a jumper to the engine, don’t recall it going thru the firewall to the dash. I’d have look when I get home, but that sounds odd.
You have a photo of this ground from battery? What gauge wire? I usually see the same gauge positive and negative side.
