100 questions
As far as the A/C goes, a used under dash should be fine as long as it is in good shape. I’d want to test the blower and see if the evap holds vacuum.
I’d go with a new compressor, condenser, and drier though.
Question 28:
Do they make a flex plate for the 151 iron Duke 4 cylinder they will bolt to a Chevy TH350 transmission
Question 28:
I believe they do, I think it’s actually the same as for a 350. But My memory is a bit foggy on this one.
Check Novak Knowledge Base
A quick peak it look compatable
I have been curious about this, and can not find a listed flexplate for a GM A/T transmission.
Question 29:
What material. And does someone sell a complete kit?
I have my chassis close to being ready to install new brake lines. Starting from bare frame so I have no brake parts.
Went on line, and decided to step back. I'm not even sure of all the parts I need.
Question 29:
Totally Stainless makes a great hard line kit, if that’s what you’re looking for. As long as you’re keeping everything stock brake-wise. For flexible lines, I’ve always been partial to stainless, especially the DOT approved poly coated stainless from Crown. (Not that Crown.) However, if you’re keeping everything relatively stock, OE style rubber lines from NAPA or your local parts store will work fine.
Question 30:
A reliable parts diagram of 1983 (frame and axles) for all parts needed and location points?
Question 31: will my 1981 Scrambler leaf springs bolt up to a CJ 5 frame?
Question 32: will a 20 gallon fuel cell bolt in a CJ5 frame?
Question 33: are the skid plates interchangeable?
Looking at a CJ5 project to buy,, to use up all my extra parts from 81 scrambler
Question 34: bad idea?
