- Galivants Ferry
- SC
Everything will bolt up. The wide track frame used a different upper shock tower for the front shocks. Hopefully you got the towers with the frame, if not they’re not that hard to find. You will need a bit longer front shock if you’re using the narrow track axle’s lower spring plate mount and the wide track frame upper tower mount.Question 20:
I have a 1981 CJ 8
I have a used later frame that had wide tracks from the factory.
Will my 1981 non wide trac springs and axles bolt up without any issues to the later model frame?
I've have gone back to widetracs. Figured that is best in long run. Yes it has shock towersEverything will bolt up. The wide track frame used a different upper shock tower for the front shocks. Hopefully you got the towers with the frame, if not they’re not that hard to find. You will need a bit longer front shock if you’re using the narrow track axle’s lower spring plate mount and the wide track frame upper tower mount.
I took the Sway bar off of my green Scrambler years ago. I didn’t really notice a difference with it on or off.Question 22:
Building chassis... didn't get stabilizer bar with used axles. I've already ordered spring hanger parts to answer question 21
Any suggestions for new front stabilizer and links, or just go stock?
