Worked about an hour on this one last night before Monday night football.
Reinstalled the headlight harness into the grill. I noticed this when I took it out, waited until now to fix it:
Both headlight plug ground wires had some serious issues to say the least!!!!! The rest of this part of the harness was good, so easy fix here.
The wiring from the Ignition control module into the main harness, and all the way to the distributor was intact/unmolested/undamaged. The only other wiring repair needed:
I ordered a new coil connector from NAPA, should be here today. The PO cut the OEM connector off when they installed the HEI distributor. Realistically, you could just splice on two spade terminals, install on coil. I did this for years in my younger days on my '78 CJ-7's with no issue. But, a new connector is less then $10, and looks much better.........
The OEM wiring (choke, Sol-Vac,
PCV solenoid Control Vacuum Solenoid) that runs over the intake/exhaust manifolds was OK, the wire tubing was not LOL. This part of the harness was originally suspended from the top of the valve cover by a little metal tab/bracket to keep it off the hot manifolds. Over time, they go missing, or the little plastic wire loom holder falls out of the bracket, and you get melted wires:
Since I am not using the Sol-Vac or
PCV solenoid Control Vacuum Solenoid, I will just loosely wrap those wires up and tie them on to the main harness for future use, if desired. The black tape on the pink Sol-Vac wiring was from me. There is a "diode" on this part of the wire, covered up with the original/deteriorating OEM fabric wire wrap stuff. I covered it all up with black vinyl tape for protection.
The Sol-Vac is useful IF you keep the OEM carburetor and add AC. The Sol-Vac will kick the idle up a hair to compensate for the load brought on by the AC compressor. You could also "hot wire" the Sol-Vac to a toggle switch, use it to manually increase RPM's when winching/jump starting/etc.
Still need to investigate the alternator wiring, but that will be it on the under hood wiring.
I am also going to make myself replace all the under hood vacuum/fuel vapor lines before proceeding with the coolant system/distributor install. I know if I get it running first I will not want to mess with the more fiddly/PIA stuff.
That's it for now!!
