1983 Jeep Srambler CJ-8
conleyire
mansfield
ma
New to forum. Doing a complete rebuild of a 1983 jeep scrambler that my father bought new in 1983 with a couple buddies. Removed the body of the jeep a few weeks ago. any and all suggestions will be appreciated. Thanks
-Pat
Welcome to the family and look forward to seeing your build, lots of great people and info on here.
We love pictures! Welcome! Don't hesitate to ask specific questions. Where are you headed with this build? Retro classic? Army Jeep?
Did I mention we like pictures?
Looking forward to seeing the progress, I am getting ready to start my 83 restoration as well. Parts boxes are starting to pile up in the staging area.
trying to decide whether to replace leaf springs or send the originals out to be refurbished (i heard that its a possibility).....pros/cons from someone who has experience would be helpful, thanks.
so since no one has an opinion on the leaf springs....i was hoping someone could shed some light on what they feel the best method is to remove surface rust from the frame
As far as the leaf springs - I've learned not to get rid of anything you might want in the future, but you'd probably be happy just storing them somewhere and buying quality replacements.
Removing surface rust from the frame I have no experience on, but when I get to that stage I'll probably try a combination of wire wheeling, scraping, and sanding with an angle grinder. After that, a little phospho-etching, priming, and painting, maybe with POR-15 thrown in there at some point.
Get yourself a big knotted wire wheel and a big grinder and go to town, unless you know a good sandblaster. There's also this stuff called MasterSeries that is great for sealing frames. It goes on real thick and self levels, so it looks great even with a brush. Comes in silver or black. I'd assume you'd want black. You can order it online or pick it up at car shows. It also has rust inhibitors in it. POR 15 is good stuff too.
Springs: Your original leaf springs most likely "fatigued" just from supporting your Scramble for he past 30 years.
The metallurgy has come a long way since 1983. I personally use and recommend Skyjacker "Soft Ride" suspensions. I've been installing them for many years now along with a couple of other "Soft" or "Easy" ride systems, but have had less problems with durability and function from the Skyjacker than any of the others. There is a huge difference in the way your Scrambler will perform in relationship to the suspension system.
With that being said, IF your 8 is only going to be a conversation piece, you can have your original springs re-arched for a lot less $$$ or you can buy a cheap set of "Stiff" springs that look good but have no flex or articulation and will beat you to pieces going down the road.
This is why the Jeep "Family" is so unique. Out of all the Jeeps manufactured since 1941, each one has the possibility to be that perfect vehicle for it's owner built exactly the way they want it and it will be appreciated by all other enthusiast.
Sorry for the looong post and good luck with your build. :wave:
