Craner8
- Orlando
- FL
Got a little accommplished tonight. Bled the brakes and tightened a fitting at the rear and re-bled. Work well. Used Dot 5 silicone brake fluid. Seems to give a softer pedal but the power brakes work well. Re-bled the clutch and it works fine.
Pulled the connection apart under the dash between the rear harness and the main harness. Discovered that the plug comes apart so switched the green wire and green wire with the tracer for the rear lights. Now the left blinker works when you pull the turn signal switch down, and the right works when you pull the switch up. Fixed. Thanks to those that suggested the fix. Plug and play with the Painless harness.
Put both front fenders on and they look great. Not as tall as I thought it might be but will add 33's later. Blew low beam on a headlight so will re-order a bulb tomorrow. HID. Very nice.
Anybody know the shifter pattern for the transfer case? Dana 300? 4 low up, 4 high, nuetral, then 2 high all the way down? That's the way it seems to work on this case.
Pics tomorrow. And its FUN to drive!
very nice build-(you need help)
