Chris, you're right. I figured it out this am and installed it although the w/s frame isn't buffed yet. Accomplished some today. A/C cools ok but its well undersized.
Installed the taillights and gas filler neck.
And I found the locking gas cap with key!
JohnN, using the 3M product behind everything, and sealing all holes with clear rubber caulking and hitting all threads with blue Locktite.
Wet sanded all of the hinges and vent cover with 600 today. Plan is to shoot one coat of green on the parts while off the Jeep, then install those that we can (hinges) and paint a final coat plus clear while on. Tape off and cover Jeep in plastic. The bolts will be body color too.
Bad pic of the column; its coming out and the tilt column is going in when the dash is ready.
Installed all bolts for the roll bar too.
Installing A/C from Collins Bros. Reviewed the installation instructions today and it references an OEM 6 point plug in the 8's wiring harness near the steering column that their 6 point plug, plugs into. I have installed a Painless wiring system and I don't see any OEM-looking 6 point plug that isn't labeled for ignition etc. Today's question: Anyone done this and if so, what I am I looking for?
Any help is greatly appreciated. Thanks.
