- gravois mills
- MO
Where is the frame vin? I'm going off the windshield and tub vin plates.I'd be curious if the VIN you are referencing, assuming it's the windshield VIN, matches the frame VIN. This thing could be quote a hodgepodge.
Even still, it's a cj8 frame.I'd be curious if the VIN you are referencing, assuming it's the windshield VIN, matches the frame VIN. This thing could be quote a hodgepodge.
Passenger side on top of the frame in the rear wheel well area. Kind of hard to see with the body on.Where is the frame vin? I'm going off the windshield and tub vin plates.
I've been going off the firewall vin and the windshield vin. They match each other and the title.Only a partial vin. First 3 letters, last 6 numbers only.
I don’t think the trans code is on the frame.
You can also look at the trim tag on the firewall under the hood. That is a complete vin.
I can. What would you like to see? It literally looks factory to me.I'd love it if you could document the details of the install. If you'd rather just send me the photos on an email, I'll get them posted up here.
Basically show exactly what makes it look factory. Column, linkages, shifter placement on the floor, trans cover, mounts, anything that shows how factory it appears.I can. What would you like to see? It literally looks factory to me.
Chris
Yep. That's what I'm thinking too. Silly.After knowing this was converted the only real flag is the way the clutch linkage punch plate looks to be sealed. It looks like they took everything of a QT Jeep and installed it on yours. Crazy
