Ignorant question, how is it that you can't make this precisely whatever you want whenever you want as easily as setting an idle adjustment screw? I would have thought something like this would have been the easiest thing ever to play with on these setup? I have a pedal commander thing for our Renegade that I can set the curve however I like in a matter of a minute, tops, via a bluetooth connected app. With these, I assumed that you'd almost have on-demand ability to play with this?
I know zero here, just going off my experience with the DBW dealio on the Renegade that I mentioned.
Trite but true, especially here and with this topic -
There are NO SUCH THINGS as ignorant questions on this subject.
The thing you're doing, which is what we do to 'understand' anything new - we like to equate IT to what we know. The old method of using a water hose as a metaphor for how electricity works, is a great example.
Unfortunately, that simplistic explanation of Carb Idle Screw adjustment being
similar to a Throttle Map doesn't hold up for this. The Pedal Commander is VERY cool, very smart piece of gear. It comes closers but only if you understand that at the heart of Pedal Commander is nothing more then a smart tap to change the curve, dwell, all timing, active and other wise (like I said, a pretty cool device).
With all electric motors, you have Profiles, usually only 3 of them and maybe modes, only two of those.
Profile is a set of tables that tell the motor how much Regen to apply and under what circumstances. Mode is more of a general 'Eco' vs 'Speed' thing.
The Throttle Curve is a thing that is at the heart of both of those.
BUT, here's the problem, setting the Throttle Map dynamically is not something you can safely change due to a bunch of dependent things as well as it's a tad difficult to 'write' to a motor while it's actually running.
ALL that being said, this motor does NOT make it easy to map or understand all the variables. Nor does it make it easy to just swap in a new or saved 'curve'. This is a clear opportunity for companies like Pedal Commander to step in at some point and provide easier ways to do this (if that's possible).
Everything on an EV is about two fixed variables - CCL and DCL - Charge and Discharge Current Limit - how much juice you can add and how much you can take out from your batteries at any given moment.
Along with those two variables is a good bit of dependent settings like operating temps, SOC (State of Charge), physical capacity of both the motor and battery module packs, etc...
I wish it was more easy and I'm sure it will be but for now, 3 Profiles only. They are exactly like the Pedal Commander's Eco, City, Sport and Sport+.
WE, on the build side, have to design each of those Profiles so you can pick them when you need them. For the driver, changing the Profile is as fast as pushing two buttons.
Building those Profiles is more involved and probably isn't the realm of the average driver.
PLEASE let me know if this helps or at least where your eyes started to glaze over so I can pull back next time...
- Patrick
