- Biloxi
- MS
Before i quit working on this one for a two month hiatus, I had pulled part of the steering column apart to change out the broken turn signal switch, investigate why the key would not lock/unlock properly, and determine why the wheel would not lock. Should have stayed in bed.
Cracked plastic turn signal switch. They typically crack where the lever screws on: (NOTE missing part, will come to this, eventually)
The lock pin that slides out and engages into the lock spring plate, locking the steering wheel when the ignition is off/locked. It is stuck in its bore. I "fixed" this on my green Scrambler with some liquid lube, and working it back in forth. No bueno on this one, it is packed full of crud.
It should be out like this in the lock position. It is hit or miss, due to all the crud in the column.
Lubed/worked the pin back and forth, got it working. Installed a new turn signal switch:
Don't forget to screw on the lever: ( NOTE the lock spring, I am missing the part the spring rests on, more on this later)
Install the plastic cam thing:
Break out the trusty lock plate compressor tool:
Pressing the plate on. NOTE, the plate only goes on the steering shaft one way, there is a gap in the splines that has to line up. This also dictates the positioning of the plastic cam/steering wheel.
The groove that the lock plate snap ring goes on:
Don't forget to put the snap ring on the smooth gold part of the tool, before installing it, like I did in the previous picture LOL:
