304 & 999 Scrambler Build
Kim Dawson
Molalla
Or
Installed the FI system with the distributor with electronics. I've been figuring out the wiring and connecting things up. I still have a few connections to make and a few to eliminate. I'm sure many of you have already done this and can steering me in the right direction. On the distributor I need a 12 V ign wire and a wire from the tach. Can I run a wire from the I terminal on the starter solenoid or is there a better place to get it from? The connector that used to go to the electronic control unit has a red w/t wire and a blue wire . . . what do I do with those? The two red wire connector that used to go to a sending unit by the oil pressure sending unit is left over . . . what do I do with that? Is there a tach wire already in the engine harness? The orange an green wires that used to go to the carb . . . what is that relay for that they come from? And finally, where should I pick up vacuum for the brake booster? When you get a FI kit, it doesn't come with instructions on what to do with your left over wiring . . . probably because the kit fits so many different years/models. Any help would be appreciated. Thanks.
Silver Member
I used the idle speed solenoid power feed to power by EFI. This is an ignition switched wire that is located at the carb. This wire is fed by the same circuit as the cigarette lighter. So, if the fuse for that blows you don’t have power to the EFI, ask me how I discovered that.
Holley recommends using power away from the alternator, ignition coil, and starter. These can all create noise that will affect the performance of the computer.
Kim Dawson
Molalla
Or
Got this overflow bottle, made by Dorman, and it fit nicely on the right side. Not bad for 12 bucks. My brake lines, meant for no booster, were interfering with the oem one. I think I have all the engine wiring sorted out.
Kim Dawson
Molalla
Or
Mounted the side rails so I'd know where to mount the storage boxes. Went to Ace and found some low round head SS screws to mount the boards for about 20 bucks . . . not the star type but this isn't going to the Pebble Beach Concours. Drilled the holes in the boxes to use the tail gate support bracket bolts. I designed the boxes to fit with the boards and still be even with the wheel wells. The vertical wood support came out even with the edge of the box. Picked up some more white paint today so when I paint the hood and windshield I can also paint the boxes. My neighbor came over and used his tool to change the ends on the plug wires to fit the GM distributor. Now the engine compartment wiring is complete. I think I like the matching SS screws even better than the two styles that AMC used.
Kim Dawson
Molalla
Or
The carpet came today. Fitted it so I could get the seats installed. The carpet kit on Ebay shows black but you can message the seller and get a picture of a bunch of blues or reds or what ever color you are looking for and they will make up the carpet in the color you choose at the same price. The molded cut pile carpet fits very well.
Kim Dawson
Molalla
Or
Been prepping the windshield frame and finally got it ready. Painted it and the storage boxes this evening. Because the other Scrambler body is taking up my under-cover painting area, I put up an EZ-Pop-Up tent to keep the trees from decorating my paint work. I need to get the hood ready for paint next.
