4 cyl cj8
2K1TJ
Still Scramblin'
Rockmart
GA
There ias a scrambler on e-bay for sale that is only a couple of miles from me. It looks decent from what you can tell in the pic. I plan on going to check it out if the seller calls me back. The only prob. is that it's a 4 cyl. Is this one that I would want to avoid or is the small engine not that big of a deal? Any estimates on the value, assuming it's in at least avg. shape(running, no fluid leaks, no smoking or engine noises, not too much rust, etc.)
Also, what drivetrain did the 4 banger come with, and would it have to be changed if I upgraded to a 6 cyl? Also, It is an '81 model so I assume it is narrow track. Do the 4 cyl. come with weaker axles? Sorry for all the ques. just trying to learn a little. I'm new to cj's
Forgot to add that the item # is 2454716278 if anybody wants to see.
Well, Like they say it all depends on what you want to do.
Are you looking for a project or a daily driver?
Almost any scrambler out there that is not really expensive and already had a frame off restoratin will really not be a canidate for a daily driver. But if you are mechanically inclined and will to take on a project they can be quite rewarding.
Now for the 81'. The 4cyl is a GM based motor. Nice but not too powerfull. Good thing is that if you want to upgrade to a gm v-6 or v-8 you have a bell housing that will work. Bad thing is that transmission is probably a sr-4 and if not already dead will not last all that long.
Transfer case is a dana 300. The very best of strength that came in the whole CJ line, IMHO. The axels are the same as on the 6cyl. A dana 30 and a AMC 20. Bad is that in 81' they are narrow tracks. Only real differance is that they are 4" narrower than later models. They would be good to 31" tires. And if that is what you are looking for then that will be fine. I would not suggest going over 2-1/2" lift with the narrows. But if you can find a newer CJ with widetracks at a junkward they are direct swaps.
Some folks do not like the AMC 20 but once you weld the rosets for the tubes to the pumpkin and put in forged one piece axels they are about as good as dana 44's. Some will argue but they are close either way, and there are lots of upgrades like lockers for the 20.
Big thing with the scrambler is to check out rust in the body and the frame and to determine if you have the ability to repair it. That is always the big thing. As this can consume a lot of time and effort. The other mechanical things can be built up but if the foundation is not good then it is better to pass and find another.
If you really just want a jeep to get out and drive and learn then I would really suggest a 91-95' wrangler. Cheap, easy, and have a good base to build from. If you do not have the mechanical gift at all then I would suggest a new TJ or the TJ-unlimited, a stretched version. This way you would have a new vehicle with a warantey. Not trying to be mean just trying to give you options.
Carl
Thanks. I've had a yj and currently own a 2001 tj sport but now am in the market for a cj8. Still learning what to look for.:)
Did'nt the 4cys have 411's If im right that could be a plus for u! Not a bad looking foundation
Description
Jeep : Scrambler
1981 Jeep Scrambler
Miles: 103000 Doors: 2 doors
Transmission: Manual Interior: Beige/Tan
Engine: 4 - Cyl. Year: 1981
Warranty: No VIN Number: 1JCBM88E5BT066507
Get the Vehicle History Report
Title: Clear Exterior: Brown
Condition: Used
4 CYL AND GEARS
Yep all the ones i've seen and worked on that had the 4 banger as the origanal motor had the 4:10/4:11 gear ratios so that's a plus if your lucky,if your unlucky maybe the 3:73s or higher.If it does have the SR-4 it will live behind the 4 banger for street use but trail use would be questional-JC
4 banger & gears
My ' 81 came with the Iron Duke, SR-4 & 3:54 gears. Running at highway speed (55 mph), I still had to shift to 3rd gear going up moderate hills. Wish it had come with 4:10's......don't have to downshift any more though :D
Robert
Re: 4 banger & gears
Robert
Hummmm......................I wonder why?;)
You really won't know what it has without looking...checking the axle tags, ect. My 82 came with a with the GM 4 cylinder, a T176 and 3.54 gears. You might get lucky!
My 4Cly CJ7 with the iron duke GM 4 came with the T5 and 4.10
I am with Mules all the 4cyl ones I have seen had 4.10 but by the look of it there is some that werent
One advantage of the 4 potter is you are never scare of breaking much other than the engine 80hp when brand new and prob now more like about 50hp is not enough to scare even the dana 30
It is also good for keeping wheel spin down, but sucks on anything realy steep or muddy where you need some ponies to get through it.
Also means that if you dont want to change the diffs and you want to keep the stock engine 31's or maybe 33'2 are the max as you run out of gear options for the amc 20 ( max is 4.56)
