I was wondering what the plus's and minuses about a 81 vrs 83 and new cj8s. I know 81 comes with a narrow track. but what else is there? Will a 81tub fit a newer cj8? And has anyone tried to put on a tj unlimited tub on a cj8?
Thanks Dan
The LJ is 9" shorter between the back of the rear wheel wells and the rear of the tub, but that's not the hard part - the body mounts are in completely different locations and the TJ/LJ frame is a lot wider than the CJ frame, so the hard part is adapting the LJ tub to the mounts on the frame, not the length of the tub.
I've seen a thread or two on other boards about putting a TJ tub on a CJ-7 frame and it's not pretty. One I remember they had to build a sub-frame under the tub so they could get mounting points located wide enough.
