- Madison
- AL
Thought I'd do a writeup on how I added an additional bow to my Bestop Supertop.
The bow that I used was a spare CJ-7 Whitco "front hoop" from a factory bow assembly but pretty much any bow should work. Got mine from Engbull on this forum.
Look him up and shoot him a message. He said he had more and to pass that on to others.
One little edit before we get started...I have since painted this additional bow Rustoleum Professional "semi-gloss black" after hitting the surface rust spots with a 3M Scotch-Brite pad and then cleaning up with some acetone. Matches pretty well with the Bestop factory bow color.
So, how I did it:
Mark 1" from the end of the thicker side of the center junction:
Cut off 1" from the thicker side of the center junction:
Add self-tapping sheet metal screw:
New bow nests nicely inside original Bestop back bow:
Bow measures ~55 1/4" across in this section from outside to outside:
Test fit in the Jeep:
Junctions match evenly:
Test fit for marking hole location for pivot point:
Hole locations 17" from the bottom of the factory Bestop bow:
Spring loaded center punches help when drilling through round tubing to keep your drill bit from walking:
So, how I did it:
