AMC 20 rebuild?
cchambers
Sioux Falls
SD
I'm rebuilding a 1981 cj8 for the first time. I need some advice on the AMC20 in the rearend.
I took it out of the jeep over the 4th and when I took the cover off.
I found someone else had been in the rear end. In stead of using gear lube. They used ATF to lubacate the gears.
The spider gears have marks on them and the ATF has that burnt smell. I don't know if the ring gear or pinion is hurt? I think all of the bearings in the third member are toast as well.
So do I rebuild the AMC20 and put mega dollers into a 30 year old rear end or look in the after market for some thing better?
Just to make you guys aware I have never set up gears in a axle before but am willing to give it a try.
Thanks
From where you're at right now, probably needing to replace everythingto be on the safe side I would opt for something else. There are a lot of options out there. A Dana 44, 9", HD AM20 and even larger options. Start looking, there's a lot of information out there.
So where should I start and look for a dana 44? My 81 is a narrow track also.
Do any of the YJ axles work? I was told thay are the same width as my 81.
Just cut off the pan bar and remount the spring under the axle?
If you're not also building this up at the same time, I'd just look for a matching good 20 and slap it in.
NT axles are given away for free all the time if you look around, tons of folks swapping them out for WTs or other axles altogether and there's very little to no demand for them outside of restoration type build folks.
The other thing would be to find a good WT set of axles and steering from someone swapping them out to go big. This gets you a little extra width and is a bolt-in swap if you get all the related parts. Cool thing here is that you'd likely be able to find someone who's put some $$$ into them with gears/lockers and save some serious coin. I found a regeared set and put in lunchbox lockers and then sold them off for a good price when I went to Wagonner axles (not a bolt in swap). If you go this route you can basically spend as much or as little as you want. I got a regeared set of WT axles for $50 off a local 4x4 forum.
YJ rears are crap axles to start with and the fronts have the diff on the wrong side. I'm fairly certain that they're not the same width either.
If you want to go bigger than that and get into D44s and/or HD AMC 20 rear (what I run) there's a number of threads here on possibilities. It takes some research to figure out what you want to do as there's a lot of options and none of those will be bolt in (well, without an aftermarket full-width axle kit at least, I think there's a couple of those that would make it a lot closer to bolt in, but I have no experience with them).
A Dana 44 rear from a Jeepster Commando 72-73 is a direct bolt in. Had one in my 82 as a temp for a year. (I ran 2" spacers to match the widetrack front, but with a narrowtrack front should be an exact swap.)
Commando rears should be cheap and easy to find.
Thanks guys I think just rebuilding and up grading my AMC 20 is what needs to be done.
All Im trying to build is a DD and light trail truck. 2 1/2 to 3 inch lift. Going to run 31x10.5x15 on stock wagon rims.
Going with a Skyjacker lift and 1 1/2 shackles from warrior.
Stock 258 dana 30 up front I think T18 4 speed has a real low first gear.
Unknow transfer case? I think it's a 20?
stay away from the 1.5 lift shackles,i put a set on mine and now cant get the proper caster angle without putting longer pins in springs to accept the degree wedges it needs to get the caster angle where it needs to be,real PITA for no more lift than it gave me and my dumb a#% threw away the old shackles before i had a chance to take it to the tire shop for an alignment.
Why do you think rebuilding your current axle is the way to go based on what folks have said here? I think you'll spend a bunch more cash than just finding another axle to swap in.
To rebuild the one you have you'll either have to pull it out yourself to take to a shop or pay a shop to remove it (it's not hard to pull a rear axle at all if you have a jack and jackstands), so you're halfway to just swapping in a good replacement and it will take a fraction of the time.
At the least just find a matching, good NT 20 and swap it in for peanuts. Don't spend all that cash on a rebuild kit and having someone do all the labor to set everything up. I'll bet good money that you can find another NT 20 and put in a lunchbox locker or 1-piece axles (or both!) for less than it will cost you to rebuild yours--after which you'll just have a stock open diff and 2-piece axles.
Here's a perfect example of the kind of deals I've seen on NT 20s:
http://westernmass.craigslist.org/pts/1825794982.html
"amc narrow trac rear end with one peice axle shafts $75 email or call 4136243404 Ben"
Not saying that's right for you or close to you, but craigslist and local 4x4 forums is a great source for these.
Now here's a link to a rebuild kit for a 20-- $117!! (and you'll add more than that in labor to get it installed)
linky to rebuild kit
Obviously it's your Jeep, but I hate to see someone spend money they don't need to and/or end up with less than they could have gotten by going another simple route.
I just finished rebuilding the AMC 20 rear and Dana 30 front, ('81) - same as yours. The AMC 20 was easier to set up, the Dana required more trial and error. I changed from 2.72 ratio to 3.73. It was my first time to do this and I really enjoyed the process, (took my time, read the manual and asked alot of questions). I welded the axle tubes on the 20 and made a truss. Since this has been done many times on this forum before I did not include pictures, (available if you want some).
Why did I spend the money on the stock axles? The AMC 20 and Dana 30 are more than enough for my needs. I do not plan to go over 31.7" diameter tires, I already have a more serious off road machine and want to keep the Scrambler close to stock. I found a set of wide track axles, ('84 CJ-8) with 1 piece axle shafts and loc-rites - so figured it would be worth rebuilding and changing the R & P. I live in the mountains, (7800') and need better gears than 2.72. If you or someone near you is going to the Colorado Scramble this month I'll make you a deal on the narrow tracks, (both in good working condition - 87,000 miles) and get them to Silverton, CO which is 24 miles south.
I found a working T-5 and I'm in the process to checking it out before I swap the original SR-4, (which is slipping out of 2nd).
So, if you think any of my experiences might help you, just let me know. I'll help you as best as I can.
This is why I injoy this cite.
I looked at the 75.00 axles and will give him a call monday for sure. If that dose'nt pan out I'll hit craig list.
I live too far to pickup the axles in CO but thanks for the offer. Also knowing that i'm not the only one trying to fix up a cj on his own is cool.
There is NO 4x4 shops where I live so it's go to the local parts house or call Morris 4x4 in florida
and I have a seven day shipment from them. There are three junk yards close by but I called them and I was told they have no CJ's laying around that are scrap.
Thanks much guys, I'm going to try and start a rebuild post with pictures.
