As promised Photos of my new scrambler .. or CJ-8
It should be 3.54 or the optional 4.10.
Is it a wide trac or narrow trac? Looking for the "date" they switched. I've had a couple of with lap belts and narrow tracs. Easiest way to determine which axle, wide shocks have shock tower and attach to axle tube, narrows attach to bracket at top of chassis and to spring u-bolt on bottom.
Rear axle , right side
There is a lettered stamp right where that little rust spot is
What's yours. ?
Sent from my iPhone
interesting, thanks for the lesson.
so early 82 it is, i also decoded the vin and it appears the jeep was originally equipped with a 4 cyl and the t-5. What would the factory gear ratio be with this combo in 82? 3.54?
Hopefully 4.10, maybe 3.73
Kk
Narrow Track AMC 20
Code Gear Ratio Diff Type
AA2.73Open
DD2.73Trac-Lok
BB3.31Open
CC3.31Trac-Lok
A3.54Open
N3.54Trac-Lok
GG3.73Open
Q3.73Trac-Lok
L4.10Open
M4.10Trac-Lok
Wide Track AMC 20
D2.73Open
DD2.73Trac-Lok
B3.31Open
BB3.31Trac-Lok
A3.54Open
AA3.54Trac-Lok
H3.73Open
HH3.73Trac-Lok
C4.10Open
CC4.10Trac-Lok
Sent from my iPhone
mini update!
so i have been talking to another member about picking up his take out 258 to put in my scrambler to get it back on the road. Seemed like a good deal was rebuilt a while ago but was a good runner, has a 2100 carb swap. Saturday i headed south about an hour and a half from me to take a look and pick it up if all looks well.
sorry i hit submit
anyway i make the trip and all checks out well so i pick it up and head back home.
I had some family things to take care of over the past couple days so i let it sit until today. my original plan was to replace the rear main, do a pan gasket and a valve cover gasket while it was out and on the stand.
I picked up all my gaskets and seals and tore into it today. i got it on the stand and removed the a/c pump and brackets and pulled the pan. All looked good and clean except for the pan gasket.
I am sure the gasket being mis-aligned helped contribute to the leaks. So i get the rear main replaced and started looking deeper and found that the #3 and #4 cam bearings are toast
So much for a good runner, this could not have been very quiet. So i tear into it and pull the head and the timing set etc. it is down to the short block now and i am not sure how to proceed. The main bearings look pretty good and dont appear to have been contaminated with the cam bearing material. I did not find any material in the oil pump pick up.
i am tempted to proceed with the following plan. Replace the cam, cam bearings, lifters and timing set (there is some damage to the teeth of the cam timing gear) I am thinking the friction of the cam bearings took out the timing set. slap it back together and hope for the best.
couple questions, what would cause the cam bearings to fail this quick?
would i be asking for trouble just replacing the above and did not do a full rebuild?
what can i do to make sure my new set lasts longer than the first? the rebuild cant have more than about 10k on it, the cross hatch in the bores look great and everything else seems tight.
this is how i left it
pretty discouraging day in the shop....
Looks like the oil holes in the bearings may not be lined up with the oil ports in the block ????
But the bearings could have easily spun.
mini update.
i have been working on rebuilding the 258 for the scrambler. The seller of the engine is a stand up guy and gave me some money back to help cover repairs. I took the block down to the machine shop to remove and re-install the cam bearings. i made an order to my favorite supply house for some internals. i picked up a new cam and lifter set (stock), timing set, felpro gasket set, cam bearings, freeze plugs and main bearings (they showed slight wear from initial startup without pre- oiling the system. I also ordered a new water pump.
While the block was at the shop i cleaned up the accessories and got some paint on them because i cant leave well enough alone.
when i got the block back i needed to get to work on a broken head bolt. it was broken about 3/16" below the deck so i built up the broken stud with weld and then welded a washer to it and then welded a 7/16" nut to the washer and turned it out.
then it was time to get some color on the block and head.
next step is to mount the manifolds and start on the pushrods/ valvetrain.
progress is slow going with 2 kids a full time job and winter temperatures.
Looking great. The progress is dependent on available time for sure. But you seem to be doing better that I would. That's for sure.
Dain
What blue paint are you using? It looks like a great match for the original blue!
the color is pontiac blue, i tried to locate some Chrysler teal in my area but was unable. I used the pontiac blue before on my cj5 360 and like it so i figure why not.
am not sure if the balancer has ever been painted other than from the factory but here is a comparison.
This project WILL debut in Moab THIS year, correct? :thumbsup: :wave:
