sorry i hit submit
anyway i make the trip and all checks out well so i pick it up and head back home.
I had some family things to take care of over the past couple days so i let it sit until today. my original plan was to replace the rear main, do a pan gasket and a valve cover gasket while it was out and on the stand.
I picked up all my gaskets and seals and tore into it today. i got it on the stand and removed the a/c pump and brackets and pulled the pan. All looked good and clean except for the pan gasket.
I am sure the gasket being mis-aligned helped contribute to the leaks. So i get the rear main replaced and started looking deeper and found that the #3 and #4 cam bearings are toast
So much for a good runner, this could not have been very quiet. So i tear into it and pull the head and the timing set etc. it is down to the short block now and i am not sure how to proceed. The main bearings look pretty good and dont appear to have been contaminated with the cam bearing material. I did not find any material in the oil pump pick up.
i am tempted to proceed with the following plan. Replace the cam, cam bearings, lifters and timing set (there is some damage to the teeth of the cam timing gear) I am thinking the friction of the cam bearings took out the timing set. slap it back together and hope for the best.
couple questions, what would cause the cam bearings to fail this quick?
would i be asking for trouble just replacing the above and did not do a full rebuild?
what can i do to make sure my new set lasts longer than the first? the rebuild cant have more than about 10k on it, the cross hatch in the bores look great and everything else seems tight.
this is how i left it
pretty discouraging day in the shop....
