Ok, the benches were an Overlander thing. The Toledo plant is the one where ALL of the World Cabs were built (go figger why they couldn't manage to sell them in the US though...) so it makes sense that that's where they came from, but I bet it was off of an Overlander Van (not that there's a lot of difference, same cool top!)
Anyway, I realized that it's easier than I thought to mount the lower hinge on the tub, there's plenty of room to reach up in there and all you should need is a decent sized piece of 1/4" steel drilled and tapped in the right pattern and tacked to the tub. Drill the matching through holes in the tub and you're there.
Did you get the striker plate for the rear door (man it's in bad shape!).
You could fab up an upper lifgate to work with the stock tailgate, but that's a good bit of work and I don't know if there's a decent amount of room up above the opening for the hinges you'd need. You might be able to get something to work out with some snaps and part of a soft top too... I have a design for a soft-sided World Cab in my head that I'd LOVE to try out... what I would do for the back would suit you just fine (it would use a normal tailgate).
Oh, did you get the rubber gasket that goes around the top of the tub and the one that goes along the top of the windshield frame? Those are key in keeping out the water, but you could probably make something work in it's place with the stick-on camper cab foam.
That's about all I can think about right now... I'll try to call you after the National this weekend. Sorry I didn't get a chance to call you yet...
I definitely think you can make that thing work on your Scrambler!
