Got to mention that Orionn/Mark from the forum here volunteered to wrench and came over for day 2. He was a major help
He worked one side while I did the other and basically made most stuff take half the time it would have with me alone (and was the only reason we got through one thing, see below), it was GREAT! Plus we talked Jeep pretty much the whole time and got to know one another.
Moved to the rear and started uninstalling things per the (pseudo) instructions. Everything was fine until we got to the instructions on how to install the cam bolts on the rear of the upper control arms.
So the deal is this, for the stock setup, the holes in the bracket are just squares large enough for the bolt. No adjustment possible. But what they do is stamp the sides of the bracket to "perforate" two tabs on either side of the hole that, if removed, would make it into a horizontal slot. The cam bolt requires that these tabs get "punched out" according to the instructions. Simple enough, right????
The problem is that there's NO WAY for one person to do much of anything to try to remove them because of all the bracketry, the driveshaft, the exhaust, the gas tank, the ebrake cables, the hard brake line on the axle, the pumpkin, the yoke, etc. etc. etc. So at this point I'm thanking the Jeep gods for sending Mark over and we start to strategize on how to get this done.
In the end, no one thing worked very well at all. We tried an air chisel and about four different cold chisel/punches. I don't think we used less than two implements on any of the tabs and a couple of them had us trying 6-8 things. It was dodgy for a while as one of the two of us was holding the implement and the other was attempting to hit it with the 3 lb. sledge without hitting all of the things mentioned above or the other guy's hand. I think I got Mark good a couple times, but he played it off like nothing. I did manage to make myself bleed by hitting myself with the sledge, so at that point I officially owned the lift kit
Here's a pic of one side of one bracket that has one tab out and one in the process of getting beat to hell with our various metal weaponry. Might be hard to tell, but you can also see how far we bent the brackets in the process of beating them seneless. We should have put pieces of 2x4 in the middle of the brackets first, but we didn't think about it/notice until we were to the last tab and went to take this picture. We were so focused on the BEATDOWN!
Here's the finished setup:
Mark laughed at me (jokingly) for being anal when I took a file to the edges of the slots and then hit them with paint. I figured all that effort was for crap if the bolts ended up unable to slide in the slot.
So in the end, these were a
MASSIVE PITA. I forget how long it took, but I'm positive this was the single longest step in the whole install by AT LEAST a factor of 5 or so. Oh, it was made worse by the fact that the tabs were much less "perforated" on one backet than the other...
For your enjoyment, Mark had a great idea and we took great pleasure in taking this picture of 7 of the 8 tabs (one is lost forever in the garage when it went flying out) on top of the instruction telling you to remove them. You can see how incredibly fukced up they got before they'd come loose.
All of that to get these things installed.... This was the starting position from the instructions. But with what I now know and mentioned above, on the LJ, without the tcase drop and motor mount lift, you should install these at this point with the long part of the "lobe" all the way to the rear of the Jeep, so basically 90° to the right from this view. That will minimize the angle on the driveshaft as much as you can and will save you the
second biggest PITA in this whole install: adjusting these things with everything else installed, which I'll get to later.
