Blazer Heater upgrade
Get PM 102 NOT PM 105
Use a hole saw of the right diameter and it should be pretty straight forward.
Great upgrade.
It's a fantastic upgrade, well worth it for those of us up north who need the heater 5 or 6 months of the year.
Inspect your heater core very carefully while you have it out. If yours is original it is due to start leaking, you'll wish you had replaced it while the heater box was out... ask me how I know :-)
My helpful hint...
Great upgrade.
When you use a hole saw, the cleanest way to cut the hole, you need to bridge across the hole for the motor with a piece of metal to center the arbor bit. It's easy to do with existing holes in the firewall. Then use the drill with the holesaw from the passenger floorboard (only works if you don't have air conditioning).
I had enough room under my dash to fit my sabre saw in and was able to use a metal cutting blade to enlarge the hole. My hole isn't as beautiful as one that would be made with a hole saw, but it is not a hack job either; in any case it seals around the motor just fine and you can't see the slight variations in the curve of the hole due to using the sabre saw once everthing's reinstalled anyway.
John N's method is definitely preferable to mine, you'll probably get a neater job using a hole saw.
Hole saw tip- drill the pilot hole with a 1/4 drill first. Then use a piece of 1/4" smooth rod as a pilot for the hole saw instead of a drill bit. Keeps the saw centered better, eliminates the tendancy of the drill bit cutting the pilot hole larger as the saw vibrates.
I took a piece of 1" bar stock and made a bridge , drilled a 1/4 pilot hole and then used the two existing holes in the firewall to mount the bridge and then drill the hole out larger, removed the bridge and WHALAAAA--Of course the heater box was removed.
Bill
I removed the fender and battery tray and used a jigsaw to enlarge the hole.
Straight8 said:
what does he mean by pm 102 not 105
That's the standard part numbers on the fan motor. You want the PM102. The difference is the shaft length of the motors and how the sit the housing properly with the fan attached.
