Body Bushings/Mounts Recommendations
JR1970
Alpine
UT
Has anyone noticed a significant difference between the available body bushings/mounts that are on the market. What do you recommend?
Thanks,
JR
Daystar
Get the Daystar 1" body lift kit, it runs about $115. I got a set of replacement poly bushing first, then I had to find all the right bolts and washers, had to use the existing bolt sleeves that were in lousy shape, installed it, and wished I'd put in the 1" kit to start with. The Daysar kit comes with the bushings, bolts and washers. I've put in 2 sets of them.
How 'bout the Bolts
What has your experience been with removing the old bolts. Did you have to tap them out due to breakage or did they come out without to much damage?
Mine are pretty rough and I'm thinkin I have some drilling ahead.
Get an Impact and hit them hard.
Also a good ammount of Kroil or PBblaster is good too.
But I have been really impressed with what air tools will do for you.
You need to watch that it does not wring off the bolt, but that hammering action really seems to help in losening the stuck stuff.
Carl
I had a few hard ones, the ones towards the rear, but for the most mine were not to bad I believe that one of the POs had them out at some point.
I did have a couple of the captured nuts broke lose and that was the biggest problem.
Use plenty of PB Blaster to break loose the crud.
The Impact wrench is a good idea but I would suggest using it sparingly until you know what the bolts are going to do, extracting broken bolts is a pain.
diddo.. Go with the Daystar 1" kit
When i did my rebuild, I put stock poly bushings back on and had to hassle with trying to find stainless bolts and washers. They stock height replacement bushings do not come with any hardware.
I'm getting ready to do another one and plan on going the daystar 1" body kit route. 1" of body is not significant enough to introduce a lot of the body lift downfalls.
Matt
i've used both the Daystar and Prothane 1" body lift bushing kits and they both worked just fine. definitely worth the $$.
matt
Replacing Body Mounts
Any recommendations if you are wanting to replace the body mounts but do not have the means or location to lift the entire body off?
If such a scenario is advisable is it best to leave some of the mounts in while replacing others so the body does not slide or move?
Is it best to start at the front or back or makes no difference?
rick
Rick,
You need:
-socket set (a 6" and 24" extension would be nice, too)
-air rachet and impact wrench (not neccessary, but highly advised)
-PB Blaster
-cutting wheel (for the captured nuts on the rear crossmember)
-5 ton jack
-(1 or 2) 4"x4"x18" blocks of wood
-12" standard screwdriver
-rubber mallet
-wire brush
-rustoleum
-if it gets ugly, a drill with tap and die set
First, hit each bolt generously several times with PB Blaster and let it sit over night.
The next day, loosen (not remove) all bolts with exception of the ones by the fuel tank and the center front one (remove them). At this time, you may find yourself using the impact wrench or even the cutting wheel (to window out the rear crossmember for nut removal).
Place the jack with wood blocks under the body in door area of one side. Jack up the body on that side to get 2" to 3" of clearance between the body and the frame (with old mounts removed).
Remove that side's hardware and disks. You will most likely need the screwdriver (and possibly mallet) to remove the fused rubber pieces.
Take the wire brush to the mount areas. Get every bit of rust you can off of the perches (it's a well spent 30 minutes). Spray them with the rustoleum and let them quick-dry. Install the new frame rail mounts loosely.
Repeat on the opposite side.
Place the wood block(s) on the rear corner of the body on one side. Jack up and replace the mount on the crossmember and the one near the fuel tank on that side.
Place wood blocks and Jack in front and replace the center mount.
Tighten all mounts.
Check your shifters (especially your transfer case) for clearance. I had to bend mine (leg press :p) so I could use 4 high.
Am I forgetting anything? :confused:
I had the same thing happen to me. After a lot of work getting those bolts out, I need to develope a plan on remounting the body. Any suggestions on how to secure the body at those locations where the captured nuts have come loose?:confused:
Body Mounts
If you go with the 1" lift; you will need to lower the radiator and the fan shroud. Also, unbolt the shroud BEFORE jacking up the body.
Not Pretty
It looks like I have the same problem as WebsterCJ8. All of the capture nuts except three of them were rusted completely loose. I'm wondering about doing a through bolt connection from the inside of the Jeep tub down through the bottom. Anyone have any other ideas for this?
It won't be as pretty but at least it will be accessible and I think I am putting in a spray in bed liner over it anyway.
Tire Size
I am considering going to the Daystar 1" is well, but mine will be lowered. There's a 3" body lift on there now, and I want to go back toward stock.
My question to the group is, what size tires will the 1" lift accomodate, and look good? I've got 35" tires on there now that will have to go when lowered, and am thinking about 31" or 32" AT replacements. Opinions? Anyone out there have the 1" lift with either 31" or 32" tires that they could share a pic or two?
Thanks,
jb
JB-8,
I have a photo with 31's. If you can shoot me a PM with your email addy I can send it to you.
Sorry, my photo files are jacked up and I can't compress them to send on a post on the board right now. (I just loaded a new photo software program)
JR
Sleeves
Does anyone know if the Daystar or the Prothane kits come with the steel sleeves? Mine were shot too.
If not, does anyone know what the size of the sleeves should be?
Thanks,
JR
