Rick,
You need:
-socket set (a 6" and 24" extension would be nice, too)
-air rachet and impact wrench (not neccessary, but highly advised)
-PB Blaster
-cutting wheel (for the captured nuts on the rear crossmember)
-5 ton jack
-(1 or 2) 4"x4"x18" blocks of wood
-12" standard screwdriver
-rubber mallet
-wire brush
-rustoleum
-if it gets ugly, a drill with tap and die set
First, hit each bolt generously several times with PB Blaster and let it sit over night.
The next day,
loosen (not remove)
all bolts with exception of the ones by the fuel tank and the center front one (remove them). At this time, you may find yourself using the impact wrench or even the cutting wheel (to window out the rear crossmember for nut removal).
Place the jack with wood blocks under the body in door area of one side. Jack up the body on that side to get 2" to 3" of clearance between the body and the frame (with old mounts removed).
Remove that side's hardware and disks. You will most likely need the screwdriver (and possibly mallet) to remove the fused rubber pieces.
Take the wire brush to the mount areas. Get every bit of rust you can off of the perches (it's a well spent 30 minutes). Spray them with the rustoleum and let them quick-dry. Install the new frame rail mounts
loosely.
Repeat on the opposite side.
Place the wood block(s) on the rear corner of the body on one side. Jack up and replace the mount on the crossmember and the one near the fuel tank on that side.
Place wood blocks and Jack in front and replace the center mount.
Tighten all mounts.
Check your shifters (especially your transfer case) for clearance. I had to bend mine (leg press
) so I could use 4 high.
Am I forgetting anything?
