Fix up Pics
This post is in need of a major update, so first here are is some of the work I did before the Jeff Daniels Show in Sept...I finished it just the night before and it did run great there and back a total of just under 4 hours. Taking the holley carb off and replacing with a factory carb made a world of difference and all the oil blow by and leaks are gone.
Engine shot after testing with new carb:
DSC04916 by
jerseyjeeps, on Flickr
Then the carb came off and all fuel lines out of the way to weld up this crack in the header..
DSC05079 by
DSC05104 by
Took this aftermarket trans cooler out which had caused the hole in the radiator on the way home and plummed the trans back into the new radiator:
DSC04908 by
Painted the AC condenser:
DSC05123 by
Installed NOS paddle handles, interior handles, nutmeg pull handles, and used interior panels from a better condition set, and both doors taken apart, greased tracks, installed anti raddle rubber tubing on the rods, and aligned driver door....
DSC05128 by
DSC05133 by
Spare tire swapped to a factory chrome rim, installed rear bumperettes in place of the tube bumper that I sold on the way home, took care of some extra wiring that went no where, and also note the construction of the 36 gallon aftermarket gas tank and the factory license plate lights for the normally wide and skinny AU plates. These light are now taken off to be painted and saved, the plate mount from the tube bumper has the two other lights as shown.
DSC05146 by
Used to have an aftermarket clock here and now has a factory one, and also had an extra aftermarket voltmeter, and a switch for the lights on the front tube bumper...so I put what looks like a factory fastener in the switch hole and an extra volt to fill the holes and make it look more factory. If I ever go the route to replace the aftermarket radio with a factory one, I will do a dash restore here too. Also took out the entire alarm system and a bunch of extra wire in what seemed like every area of the Jeep. That little LED next to the light switch indicator is leftover from the alarm.
IMG_1928 by
And a Current Engine Shot:
IMG_1948 by
Also a list of other things I did:
NOS front frame cover installed
NOS front turn signal assemblies installed
Original Front chrome bumper installed
Removed heater core bypass under hood and cable under dash
Removed dual electric fan setup, ARB compressor, OOOOGA horn
Installed Factory Horn
Installed standard 4 blade fan and extra spacer (to clear dual belt A/C compressor)
New Radiator and system flush
Rebuilt side mirrors with new bushings, NOS brackets, factory mirror heads and painted arms
Got the A/C compressor working again
Cleaned and painted frame and cleaned up other areas underneath (lots of AU red dirt and clay)
New washer bottle and pump
Removed aftermarket rear speakers
Fixed under dash lights - plans later to make them door-opening along with the dome lights (holes are there from alarm switches)
Polished Rims
And More
More pics coming soon, but its time to go enjoy Friday Night. (:beerchug) I hope to have those up later in the weekend.
