- Landing
- NJ
More Pics
And here are some other pics...
The 36 gallon gas tank from the side..you can see how it angles up, it is basically a big L that wraps around the inner crossmember...also from this pic you can just barely see the truss kit on the AMC 20:
IMG_1978 by jerseyjeeps, on Flickr
A rear window:
IMG_2011 by jerseyjeeps, on Flickr
Dash... Replaced the tach with a better one and also the steering wheel and center cap...the little indicator to the left of the heather fan control is for the floor mounted E-brake and lights up Red.....Still need an original glovebox door, grab handle, and a few other things...and yes that AC unit is huge I wish it would fit under the dash better but since it is so big it did do a great job of cooling the big greenhouse in the 105 degree heat on the way home...when it worked
Also have measured for a factory U.S A/C unit and because of the opposite heater box setup, it wont fit, not even close as the motor part hits the box on the left side.
IMG_1925 by jerseyjeeps, on Flickr
And a few other pics...
IMG_1972 by jerseyjeeps, on Flickr
IMG_2002 by jerseyjeeps, on Flickr
IMG_1973 by jerseyjeeps, on Flickr
This bracket behind the tailight prevents the tire from crushing it. It was rusty so I blasted it and painted it.
IMG_1974 by jerseyjeeps, on Flickr
This is the export tag which is near the brake booster bracket... there is also a regular U.S. firewall VIN tag over on the LH side near where it normally goes.
IMG_20301 by jerseyjeeps, on Flickr
And this sticker is on the firewall down low on the RH side, below where on U.S. CJs the heater motor sticks out.
DSC05152 by jerseyjeeps, on Flickr
A rear window:
