Hey guys, I have been a Jeep owner most of my life (33 years old) and I have owned everything from a 46 2A to a 2005 Wrangler. I have been patiently waiting for Jeep to produce a Wrangler based pick up, but it doesnt look like this is happening anytime soon.....and with the quality of Jeep being less than ideal, I don't know if I would want one anyway.
I need a pick-up for work and home use, and I want another open top Jeep for cruising around in.....plus I am looking for a project......and another hot rod is not practical for where I live now.
So here is my idea I have been kicking around lately........build a new Scrambler using aftermarket frame and body, new axles, and a crate engine..... its something that I had originally planned to do with a CJ-2A, but couldnt justify the cost of that project as a toy only.
My budget is around 30k as this is what a new Jeep or Tacoma pick up would cost. I have cash available to finance the project.
I was thinking about using the following:
* Throttle Down Kustoms Frame with YJ spring mounts. YJ springs because aftermarket axles are available for the YJ configuration.
* New Axles (44's) for the YJ spring mounts
* New Reproduction Steel Body
* GM Crate engine 350
* NV-3550 or NV4500 Transmission
* Transfer case ???
* Factory interior, steering, gauges, paint and decals.
* Factory chrome rims with 31 BFG AT or MT tires.
I was thinking of buying a rusted out beater of a Scrambler for the title and tags, and to use for the misc parts and as a template for the new body. I would stay away from fuel injection due to increased cost and complexity of fuel system, and go with a simple aluminum intake and off-road carb. Painless wiring would cover the wiring and give me extra room for accessories like a winch, lights, etc.
I ran the numbers and I am right at 25-30k depending on the use of new or salvage yard drivetrain parts, and whether or not I attempt the paint.
I have a Millermatic 211 auto-set mig welder, compressed air, and all the tools I need with the exception of paint supplies. I have done all of the mechanical work with the exception of setting up ring and pinions, which I wouldn't have to do if I bought new axles.
So what do you think? Any ideas on specs for the frame......should I have anything custom done that would be beneficial? I was thinking just a factory spec frame, with the exception of V8 mounts and YJ springs, but I know there are options for higher body mounts, etc.
What Transfer case should I use? I initially thought about an Atlas but that tacks on 2k to the price of the build.
Also, I briefly thought about buying a rolled or wrecked late model Rubicon and swapping the 4.0L, and drivetrain, axles etc, and having Throttle Down Kustoms build me a custom Scrambler frame with TJ mounts for the suspension coils and axles, motor and trans.
Does anyone have any experience with the reproduction steel bodies? I know the ones for the MB and 2A are pretty accurate now and with the exception of the angle of the E-brake handle and the lines on the top of the rear wheel houses, are pretty hard to tell from factory....I wonder if the CJ-8's are as accurate?
* Transfer case ???
