CJ in Garage for Winter Whats Your Plan?
jpdeuce said:
I agree with Kopecki...
What is this "winter" you speak of?
Ba$tards! ;) :D (mentioned while preparing for the Michigan Winter)
My goal...get the Scrambler project running for Spring - not one particular project, just...well, everything. Wiring, trans linkages, etc. The wiring will probably be the most time consuming, given the grounding issues with the fiberglass body.
I also have a Ford 8.8 axle that I'll be getting ready for install in my YJ in the Spring.
Craig
Garage? Is that the thing so full of crap that the walls are bulging?!
How in the world does anyone have room for a vehicle in their garage?
One of my 'fall' projects IS to organize/clean out the garage such that I might be able to get my Scrambler in to work on it.
Projects:
1. Brown Scrambler
a. Attend to nitnoids and get it running & on the road after last spring's motor swap & tranny conversion (manual to AT). :rolleyes:
b. Install split bench seat.
c. YJ brake MC/booster upgrade.
d. Family cage.
e. Fix fuel & temp gauges.
f. Heater blower motor upgrade.
g. MAYBE lift 2" & swap axles w/ ones from red -8. (2.73 to 3.73's.)
2. Utility bed J-20:
a. Install motor (360) - anyone know of a source for a good one?
3. Red Scrambler
a. family cage
b. Iron out wrinkles:rolleyes: on driver's side.
c. Replace rear bumper w/ one incorporating tire carrier & gas can rack.
d. Recover front & rear bench seats.
e. Pad rollbar/cage.
f. Fix fuel & temp gauges.
4. 'Kid's' CJ-5 (will also serve as my engine testbed)
a. Replace manifolds & carb (stolen for red -8).
b. (Hope to) swap on super wide & lower-geared J-10 axles.
5. General:
a. Find a post-military job. (Anyone know of any good paying jobs for a shiftless ignoramus that involves little work and occasional destruction of men & equipment? ;) :p
b. Prep to relocate.
c. Buy a trailer.
d. Look into 4.0l HO head & EFI upgrade.
Now.... let's see if I can get even 50% of the above completed?:confused:
1x1_Speed_Craig said:
... given the grounding issues with the fiberglass body...
I've never understood the big concern with "grounding issues" on fiberglass bodies.
Other than grounding the dash plate and running a nice, fat, solidly grounded wire along with the rest of the wiring to tap off of where needed, what's the big deal? Is there much else on the body that needs grounds other than the taillights?
I know there are a handful of things I need to do this with...I'm just now getting to the point of looking into them. It won't be a major deal; I just need to do some homework to make sure I have things covered.
Craig
rebuilding mine in the snow
I am trying to get the flattie ready to pass inspection so I can push snow with it.
I would like to find a space in the garage somewhere infront of project landrover to rebuilod a 258 with fuel injection for my 1981. I just bought a case of spray undercoating for the 1982 as it will be the driver throught the winter. GOt out the tirechains and made sure they fit over 35 inch tires. Put the snow brush and scrapper in the jeep and a snow shovle in the back.
Re: Garage? Is that the thing so full of crap that the walls are bulging?!
That should be tops on my list :D
Jerry, I've seen your garage..I think you will be lucky to complete this ;) . Might as well forget workin on the scramblers, so I'll just come down there and take them off your hands so they don't cause any distraction to gettin that garage sparkly..:p
Truck
I wish snow salt on the roads was my only rust causer, I've already had mine through enough saltwater this fall to make me wonder what's going first. Why do sika deer have to live in spots where the tide comes over the roads so much?!?!?
After hunting seasons mine will go in the garage for winter. This year's list include:
1. Finish the TJ flares - I only got one done last spring and drove it like that all summer. :(
2. Body work, paint, line the tub.
3. More lights - I made a custon switch panel last winter under the dash and put four switches on it, only using two at present. Thinking of a pair of fog lights, one in the cab for more light inside, one on the rollbar or spare tire facing backwards for loading the bed at night.
4. Generally pull apart, sand, clean and paint any part that hits me at the moment.
4800 sq ft shop with 2 arc, 1 mig, and 2 gas powered arc machines, plasma, ironworker, 8' metal brake, overhead hoist, stocked with air and manual tools, and a big skid steer all under the roof with plenty of room to spare. Steel yard out back, and if its not there it can be the next day.
But in College Station I don't even have a garage. Just a 10x12 shed and the bed of dodge. But I've got 2 shops to use whenever I want, just have to work on some stupid toyotas and a scout occasionally. One shop's even got a lift, and some 1000 hp 3rd gen camaros.
Hey op law
You can always go work at ROADWAY after two years max rate is $22.77 hr. We always need dock lawers er stewerds, destruction of freight is frowned upon but known to happen and we hire lobotomized chimanzees to move freight so a n ignoramus is not to much of a leap. On second thought don't cause the hours suck and hell for some one smart is working with idiots. Can you tell I love my job as much as it lovess me.
